Hi all this is my first post.
Spec's :
Hardware:
Case: Danger Den Double Wide Tower
CPU: Intel® Core™ i7-980X
Motherboard: EVGA X58 SLI Classified 760
RAM: 6GB DOMINATOR GT 1866MHZ 7-8-7-20
GPU: two SAPPHIRE HD5870 1GB @crossfire
Sound Card: Auzentech X-Fi Forte
Hard Drive: two Vraptors 300gb RAID0
Monitor: DELL 30" 3007WFP-HC
Fan controller: Two Lamptron FC5
Cooling :
CPU loop:
CPU block: EK Supreme HF nickle plated
Radiator : Black Ice GTX360
Fans: 6x Scythe Gentle Typhoon 1850RPM "push-pull"
Pump: Two MCP355 + Heatkiller dual top
Reservoir: EK-RES150 Rev.2 Multi-Option
Fittings: bitspower true silver compression
Tubing: PrimoFlex Pro LRT -7/16in. ID
GPU & Chipset loop:
GPU block: Two EK-FC5870 - Acetal+Nickel + Aluminum back plate
Motherboard block: EK-FB EVGA X58 CLASSIFIED Acetal+Nickel
Radiator: Black Ice GTX480
Fans: Scythe Gentle Typhoon 1850RPM
Pump: MCP355 + XSPC single top
thanks to HF for providing most of what you see .
Spec's :
Hardware:
Cooling :
CPU loop:
GPU & Chipset loop:
