K. so another update in quick succesion :shock:
I finished all the work i could do today so ere is the progress so far:
To get it a view of what i did:
Beside drilling out the wheels and the shaft on the mobo side ( and no worries i am gonna put it back i just needed the room to work in )
I drilled the holes for the covering bracked, couse i really hate that big hole for youre wires, its ugly and unpracticle like hell !!!
I drilled another whole for the cables from the front bay.
I also cleared out the rest of the holes a bit more couse the power cables diddnt fit yet.
Beside those things i also removed the to strips from the front :
These are ugly as hell so i'm gonna remove that carbon wannabe paint job and pollish em to a nice shine.
I also did a little extra work on my 360 rad:
i found a nice cable route so you wont see the fan cables:
The result:
Beside that i cut the rubbers to size :
This is needed sadly couse between the fan and the rad i need to fit the rad holder as well. and i could fit em all together, so i cut the rubbers to size to fit the rad holders:
Now these are the things im holding on right now:
- the rubbers for the tubing to run trough, without them i dont know how big the holes will be.
- rivets, i need to get the right size to get my case back together and ready for powder coating ( yes its gonna be powder coated )
- polish to get the front polished
So i hope to get some more updates soon
