Project for S-RV-SE BloodRage WC
the Vapochill Classic R404 is not strong enough to cool the i7 on good OC.
The Custom TEC mounting with led's is already sold, but now i'm busy with Gulftown Westmere Q3QR 3.07Ghz on ethylene Glycol that on his part is cooled by 30 TEC modules to get sub ambient temps to get 5Ghz on 12 treads stable.
i'm just finishing up the case mod, then the inside with TEC's and all.
I know the Vapochill Classic is not strong enough for i7 im just showing this build Vapochill Mod i did in 2002
Using intel 3.2 EE & Abit IC7-MAX3
Somes update here's the Red filters mod i did on the front panel display i had to remove the front lenses on 2 devices but it turn out ok with the red filter alone
and i try a red lightstrip muckup around the devices front bezel it look better in real sorry my digital camera sux & blured
and i add a new LG Blu-ray Burner 8X WH08LS20
Side By Side first 2 pictures ares muckup photoshop the right picture is genuine blue color
let me know what you think about the red theme
Heya guys well here's a update for the 480 GTX & the trim +f 120mm Fans + Mouse Mod Done & Dominator Extended Fins in Red
the paint is base coat & as been Mixed with tinner so it's like Primer + i had micro aluminium in the paint for conductivity solution
G Project Bloodrage Gallery & Build Logs 81
