Primochill D5 reservoir
ShaquilleMoreno
Senior Member
Deze topic is ook voor nieuws: de Primochill Typhoon III
PrimoChill:" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
PrimoChill: zei:
Although it obviously will not run two loops as well as it would one, it comes closer then you might think, and certainly closer then two loops created with “Y’s” or “T’s” or manifolds. It will outperform a single loop that feeds both a CPU and video card/s in cooling power because all components are getting cooler water—you’re not feeding preheated water from one component into the next component on the chain.
Leuk ding. Ik zie dat ze zelfs een uitvoering gaan maken met 8 aansluitingen :118:
Het ziet er trouwens wel heel netjes afgewerkt uit.
bundymania [User Review] English Version: Primochill Myriad Dual Bay Reservoir D5 - Clear HighFlow Product Reviews 0
bundymania [User Review] Ausgleichsbehälter: Primochill Myriad Dual Bay Reservoir D5 - Clear HighFlow Product Reviews 1
damunk PrimoChill Typhoon III Reservoir System HighFlow Product Suggesties en Nieuws 70
J Primochill PETG tubing 3/8inch 1/2inch (10mm/13mm) HighFlow Product Suggesties en Nieuws 2
anub1s18 Primochill Rigid Tubing finishing bit HighFlow Product Suggesties en Nieuws 8
S Primochill Vue Koelvloeistof / Liquid / Coolant HighFlow Product Suggesties en Nieuws 108
XenoMorpH PrimoChill 1/2in. Rigid PETG Tube – 4 x 36in. – Black Waterkoeling 4
D PrimoChill Revolver SX fittingen HighFlow Product Suggesties en Nieuws 10
S Primochill PETG Tubing 1/2OD 3/8ID HighFlow Product Suggesties en Nieuws 1
D PrimoChill PETG tubing HighFlow Product Suggesties en Nieuws 0
AQuAKiNG primochill slang 15,9/11,1 mm HighFlow Product Suggesties en Nieuws 2
D PrimoChill PrimoFlex Advanced LRT 3/8 ID - 1/2 OD - Crystal Clear Retail HighFlow Product Suggesties en Nieuws 1
H Primochill Versatile Rigid Tubing Bender HighFlow Product Suggesties en Nieuws 4
S EK-Fittingen & Primochill Advanced LRT tubing Waterkoeling 4
Hightower PrimoChill Rigid Ghost Compression Fittings HighFlow Product Suggesties en Nieuws 12
Hightower Primochill Acryl Rigid tube blauw HighFlow Product Suggesties en Nieuws 4
Hightower primochill lrt advanced 10 mm id 13 mm od HighFlow Product Suggesties en Nieuws 1
Hightower primochill lrt advanced 10 mm id 13 mm od HighFlow Product Suggesties en Nieuws 3
H Primochill rigid tubing met bijbehorende fittings HighFlow Product Suggesties en Nieuws 0
D PrimoChill Flexsleeve Kit UV BRITE ORANGE HighFlow Product Suggesties en Nieuws 4
S PrimoChill Flexsleeve Kit Blue HighFlow Product Suggesties en Nieuws 5
bundymania Review: Comparison between 3/8" + 5/8" Tubing - Tygon-Masterkleer-Primochill-Koolance HighFlow Product Reviews 5
Alex Primochill Typhoon Split Window Reservoirs HighFlow Product Suggesties en Nieuws 0
D Koppelingen primochill III Waterkoeling 11
Mobomonster Primochill dingetjes HighFlow Product Suggesties en Nieuws 6
Thierry Primochill coolant HighFlow Product Suggesties en Nieuws 20
B Primochill 1/2" clamps HighFlow Product Suggesties en Nieuws 3
E Raijintek RAI-R20 reservoir HighFlow Product Suggesties en Nieuws 2
anub1s18 Singularity Computers Protium Reservoir Tube Replacement 100mm? HighFlow Product Suggesties en Nieuws 7
ShockRaver [Te Koop] BarrowCH Boxfish series Acrylic Square Digital RGB Tank Reservoir 150mm - Black Verkocht 1
Jason Singularity Computers Protium 150 D5 – Reservoir Combo HighFlow Product Suggesties en Nieuws 0
P Shuim bubbels in reservoir Advies Waterkoeling Setup 2
