UPDATE TIME!
Sponsors:
![](http://cartel.parvumsystems.com/pl/alphacoool.png)
![](http://cartel.parvumsystems.com/pl/phobya.png)
So to continue with the rebuild to get all the cable management in place. We did it almost in a backwards fashion. No cable holes initially then after a full rig build mark up the exact measurements and cut again. Long winded indeed but gets the finish we wanted.
60mm
Alphacool back in place:
Gentle
fans installed via the second layer/accent panel:
Would like to welcome
Pexon on board. We met James from Pexon at iSeries and got to spend a good bit of time together. We have actually traded work for work here and this is a shot of the PSU as you may have seen already if you follow his work:
Next some floppy tubing that needs to be used in places that wont be seen in the final. It was impossible to not use any in a build so small but it wont be seen. Also the 8pin EPS for the motherboard:
With the Enermax
fans installed:
And as promised the
EK block changed to clear/frosted:
We had been lucky enough to part exchange an old card for a second GPU and got the matching block for it. SLI connector goodness here from
EK:
A little idea of what is going on up there to make this thing all happen. Lots of holes, lots of mad connectors. Excuse the mixture of
fittings. These won't be visible so it didn't have to all be
bitspower
So now because of the second GPU that we didn't take into account efficiently we had to change the tube routing. It doesn't look as amazing as the all in line tubing but after seeing it filled with tester fluid it still looks amazing and we are really happy.
Here are some photos of the
fittings and changes:
A few random shots of the PSU cables and the top chamber, starting to take shape:
To end the update a few shots of the routing system. Though not all direct to the top they work really nice and straight tubing is killer:
Again thank you SO much for reading. It means everything to us. Please throw questions, advice and/or ideas at us!
See you on the next one!! :rock:
