O11D XL hard tube
tdesmet
Hallo iedereen,
Mijn eerste hard tube build net afgerond en ik moet zeggen dat het resultaat er mag wezen! :)
PC
Case: Lian-Li O11D XL White
Mobo: Asrock X570 Phantom Gaming X
CPU: Ryzen 3700x
RAM: 32GB Corsair 3200/16
GPU: RTX2080Super FE
SSD: Samsung 970EVO 1TB
Fans: 7*Corsair QL120
Waterkoeling
Blocks: EK Velocity + EK Vector RE RTX2080
Rad: 2*Hardwarelabs GTS360 Nemesis
Res/pomp: Lian Li G1 Distro Block DDC3.2 pomp
Tube: EK 16/12mm
Fittings: EK torque
Fluid: EK cryofuel premix - acid green, transparant
Accessoire: Bitspower flow indicator
Groetjes!
T O11D XL hard tube + beperke mod Gallery & Build Logs 3
Jason EK-Quantum Reflection PC-O11D Mini D5 PWM D-RGB - Plexi HighFlow Product Suggesties en Nieuws 0
Jason EK-Quantum Reflection PC-O11D MINI D5 PWM D-RGB HighFlow Product Suggesties en Nieuws 0
Jason EK-Classic DP Front PC-O11D D-RGB + SPC PWM HighFlow Product Suggesties en Nieuws 0
B hard tube onderdelen Gezocht 13
Jason BarrowCH Heatsink for 2280, 22110 M.2 SSD Hard Drive with OLED Temperature Display HighFlow Product Suggesties en Nieuws 0
Jason Barrowch G1/4 - 14mm & 16mm OD Wolverine Super Anti Off Hard Tube Push Fitting HighFlow Product Suggesties en Nieuws 0
Jason Barrow 14mm OD - Twin Seal Hard Tube 90 Degree Compression Fitting HighFlow Product Suggesties en Nieuws 0
Freddy EK-Loop Modulus Hard Tube Bending Tool HighFlow Product Suggesties en Nieuws 0
T Hard tubing buigen Waterkoeling 16
Freddy Hot Knife - Touwbrander - Sleeve and Rope cutter / snijder, voor de die hard sleevers HighFlow Product Suggesties en Nieuws 0
toosgrandioos TFC / F1 Racing hard tube fittingen HighFlow Product Suggesties en Nieuws 2
Sw333t [GEVONDEN] 2,5" Sata hard disk Gevonden 1
H [Casemod] GAME HARD, FOLD HARDER Gallery & Build Logs 162
J [2013] A good day to DIE HARD (5) Films / Movies 9
maomanna Lian Li EX-23N Hard Disk Expansion Kit HighFlow Product Suggesties en Nieuws 4
k.3nny k.3nny CleaN-TJ07 *build for WWW.HARD.FM Gallery & Build Logs 32
P Corsair 800d "Dick Hard" Gallery & Build Logs 33
Sanders Hoe hard draait je standaard PC? Algemene Discussies 15
Don_Holio Hard-core party wanted Algemene Discussies 8
ZwerverRoodbaard Hoe hard kan de fan van jullie grafische kaart draaien ? Algemene Discussies 29
Freddy Wat is zuiniger? Films afdraaien vanaf USB-stick of Hard Disk? Hardware & Software 20
Bl4ckj4ck666 Soft-tube id 1/2e Waterkoeling 9
Bl4ckj4ck666 Soft tube feser HighFlow Product Suggesties en Nieuws 1
anub1s18 Singularity Computers Protium Reservoir Tube Replacement 100mm? HighFlow Product Suggesties en Nieuws 7
Jason EK-RES X3 150 & 250 D-RGB Tube Reservoirs HighFlow Product Suggesties en Nieuws 0
Gurt11 Incompatibiliteit 14mm tube - EK HTC Classic 14mm fittings HighFlow Webshop 2
