Nvidia introduceert GeForce RTX-videokaarten: RTX 2080 Ti, RTX 2080 Ti en RTX 2070
l3p
Ik stoorde me alleen aan het woordje 'meeste' :)
When it comes to the AIB partner cards, though, we were more successful.
Connor Richards, public relations manager at Overclockers UK, told Digital Trends that,
“The unwanted return rate is slightly higher on the 2080 Ti than other cards, actual faults are very low though.
Average return rate is about 3.5 percent with 50 percent of those being returns under the 14-day return policy.”
The two highest selling cards Overclockers UK has had in the past couple of years display similar number, he told us.
They averaged a 3.34 percent return rate, with around 46 percent being “unwanted,” rather than failed cards.
Those numbers suggest that the AIB partner 2080 Ti cards are as reliable (if not slightly more so) than most graphics cards.
However, those numbers are skewed slightly favorably due to the relative youth of the GPUs.
We also received tips from several GPU manufacturers on the condition of anonymity, that they had experienced no issues with new cards
One well established, UK-based system builder told us that they had seen zero failures among the 2080 Ti-equipped systems.
that they had experienced no issues with new cards, 2080 Ti or otherwise.
Harji Chana, COO of gaming PC builder, Digital Storm, told Digital Trends that they hadn’t seen any kind of “alarming” return rate on RTX 2080 Tis.
Famed overclocker Der8auer released a statement video for Caseking, citing failure numbers for the “thousands” of AIB partner 2080 Tis sold as around 1.4 percent.
That’s noticeably higher than the 0.1 percent of returns for the 2080, but still far from substantial.
l3p
SLI moet je helemaal niet meer aan beginnen. Meer en meer spellen heb je juist minder FPS of zelfs vastlopers.
Aflopende zaak.
Alecs010
Aflopende zaak.
Ja dat is ook wel zo, ergens hoop ik toch dat het er weer komt maar ja de kaarten die ze maken trekken het prima indd.
[MENTION=4050]Hightower[/MENTION]: die ind ik net iets te prijzig om er 2 van in te zetten :p
Hightower
chef prutser
Gewoon eentje erin zetten,is meer dan genoeg.
Heb zelf de titan x pascal en ook maar eentje.
Speel alles op ultra op 3440/1440.
ForresT
Gezien het minimale prestatie verschil zou ik er gewoon een leuke 2080 ti in zetten en deze voorzien van een koelblok en een mooie overclock geven.
geen SLI levert direct verlaging van €750 a €1000 (zonder de SLI-brug)...
welk extra budget geeft voor waterkoeling of dergelijke.
Maar ik begrijp @Alecs10 ook wel, het oogt nu eenmaal erg monstreus
l3p
Een jaar of 3 terug was ik helemaal klaar met al die bende in mijn pc.
2 GPU's - 4 x power, 3 x HDMI
3 Schermen - 3 x power, 3 HADMI
4 HDD's - 4 x power, 4 x sata
1 Raidkaart - 6 x sata
2 SSD's - 2 x power, 2 x sata
2 DVDR - 2 x power, 2 x sata
843437 Kabels
Alles eruit gegooid, vanaf toen:
1 GPU - 1 x DP
1 Scherm - 1 x power, 1 x DP
1 SSD - M.2
(storage naar NAS)
Heerlijk zeg die 'simplicity'
2,5 jaar met een single Titan X (Pascal) wat gewoon snel genoeg voor wat dan ook met enkel scherm.
Nu een enkele 2080Ti en hoop weer 2 jaar vooruit te kunnen.
MrGiorgio
De Planner
843437 Kabels
Scheelt je zo ongeveer ruim 840.000 kabels op maat maken en sleeven :112:
Wat een tijdswinst.
Sowiezo vind ik al die (overbodige) kabeltjes een afbreuk doen aan de looks en de airflow.
Dan reageer ik speciaal niet op het aantal (redelijk) ruim geschatte aantal kabels (ik wou niet "die kerel" zijn)... :p
Huidige pc heeft ook weinig extra, ook geen plaats voor bij zo'n ITX (CM elite 130)
Nu (tussendoor) bezig aan CM stryker SE, kast zoals een boeing 737... denk dat het niet zal aankomen op kabeltje of 2.
Maar of het knap te krijgen komt er idd wel extra werk te pas om knap te maken en/of kabels weg te stoppen...
maar gezien ik bij eerste eigen pc en updaten van neef zijn pc opmerkte dat het bezig zijn aan pc bouwen een erg kalmerend effect heeft op mij vind ik dat niet erg.
Alecs010
Ja had het gezien is wel van 26 oktober 2018 :). als je wat jongere filmpjes kijkt is het in sommige games stukken beter geworden maar ook nog steeds games waarbij het minder is. Of zelfs niet ondersteunt word.
Even nadenken nog ;)
