MDPC-X is terug, en verkrijgbaar bij HighFlow :)
Nieuw kleurtje :)
Mellow-Yellow by MDPC is the most beautiful warm yellow shade of the whole yellow spectrum. “Mellow” stands for a color which is smooth, rich, pleasant and free from harshness. Of course it is highly fluorescent under UV Blacklight too.
MDPC-Color is a class of its own in the industry. While being fluorescent, it still provides maximum opacity. With the highest Quality german UV protectors included, it shows no color degredation over time and no aging effects of the material. MDPC sleeving: No compromise in color and constant manufacturing quality.
[FONT=&quot] [/FONT]
En weer een nieuw kleurtje van MDPC-X: XXX-White!
XXX-White is the most intense white cable sleeving ever made here at MDPC-X since 2007, even exceeding the legendary predecessor "White-X" in terms of brightness. XXX-White sleeve is extremely fluorescent when exposed to UV-A blacklight.
Whenever XXX-White is exposed to natural daylight, it unfolds its full potential of brightness and intensity. XXX-White will then reveal its clear difference to any other white cable sleeve. XXX-White was purely designed to be the most extreme white shade and we achieved this with our latest German color creation technology - of course without using lead (Pb), which you would typically find in Asian productions.
If XXX-White is too extreme for your purposes and you prefer a less "hard" white shade with a softer appeal and a natural intensity (without the extra daylight boost), please have a look at our alternative white shade cable sleeving: Natural-White by MDPC-X.
Nieuw kleurtje van MDPC-X :)
Let's open the MDPC valves for new products and colors in 2017. Here we go with our latest color creation, the purest orange shade within the spectrum: Papaya-Orange! Highly UV-reactive and of course the peak of today's cable sleeving manufacturing from base-material creation to final production, 100% made in Germany. Papaya-Orange is now available to all of you!
MDPC-X Papaya-Orange is the pure orange shade within our color spectrum. In the sports car industry it is the typical choice when it comes to orange paint jobs. In the computer industry it is well known from the highly recommended BeQuiet(TM) products. With our new offering, we will further push the possibilities of your designs, when it comes to a perfect orange shade.
The high UV-reactivity properties of MDPC-X Papaya-Orange cable sleeve, make it pop under natural daylight influence and truly glow under UV-A blacklight. Purest orange in every environment is guranteed. With our uncompromising color creation and fabrication technology, you can be assured to have the best possible orange cable sleeving in your hands and as an essential part of your project. No color or material degredation over time, no manufacturing flaws out of the box: As always, a class of its own!
En weer een nieuw kleurtje :)
After Papaya Orange, we herewith present the logical addition to complete the most legendary racing color scheme since the raw 70s: GULF-Blue is now a reality!Gulf-Blue is the most legendary color in racing since 1970. Especially known as the "Gulf Scheme" in combination with our Papaya-Orange plus some black and white. Gulf-Blue is by far the lightest blue shade, which we ever created. It has a very "icy" appearance. Of course we maxed it out by making it extremely fluorescent at UV influence by daylight or UV-A blacklight.
It is another demonstration of our class leading German color creation and base material technology, because the extremely light colors like Gulf-Blue demand the best in opacity while still keeping the color brilliant and saturated. Having the maximum in UV reactivity on top is the final demonstration of our leadership in cable sleeving manufacturing. And because these things are still not enough for us, we also added our famous UV stabilizers, so there is no material or color degredation over time, no matter where you use our product. 100% Made in Germany, 100% no compromise!
ik deed vroeger altijd de small omdat het enkel dat was. maar nu die XTC uit is lijkt me dit makkelijker? minder kans op error?
is trouwens voor een fractal design meshify 2. hoeveel meter is daar ongeveer voor nodig 1GPU met 2x8pin?
XTC is wat nauwer geweven, qua formaat scheelt het niet veel.
De kleuren zijn toegevoegd:
Hoeveel meter je nodig hebt is afhankelijk hoe lang de kabel moet zijn.
Kan je zelf even meten/schatten, als het bijvoorbeeld 50 centimeter moet zijn -> * 8 = 400cm = 4 meter.
Je kan altijd beter wat meer bestellen, zodat je foutjes kan maken etc.
pilotter MDPC-X Heatshrink 4:1 MEDIUM - black HighFlow Product Suggesties en Nieuws 2
Mannozels MDPC-X Crimp terminals voor ATX 15-16AWG HighFlow Product Suggesties en Nieuws 2
Freddy MDPC-X Hook-Up Wire (Stroomdraad/kabel) en nieuwe Crimping Tool CTX3 HighFlow Product Suggesties en Nieuws 0
Legendary1985 [REFUSED] Enermax MaxRevo 1500W MDPC-X gesleeved Verkocht 2
Oli4v [VERKOCHT] Corsair HX750w MDPC-X sleeved repost met kaartje ! Verkocht 2
Oli4v [REFUSED] Corsair HX750w MDPC-X sleeved Verkocht 20
Oli4v Corsair HX750 MDPC-X sleeved Gesloten 9
kier [GEVONDEN] Rode Mdpc sleeve small Gevonden 3
Legendary1985 [CANCELED]100m 3mm Rode sleeve Mdpc-x + benodigde accessoires Verkocht 13
M5rvii [INACTIVE] Mdpc sleeve Gevonden 2
Sw333t [FANS] 2x San Ace fans met MDPC-X sleeving Verkocht 6
D Darth's "YDA-MDPC" Project Gallery & Build Logs 464
M MDPC-X sleeving HighFlow Product Suggesties en Nieuws 4
B Weer terug denk ik Introductie: Stel jezelf en jouw PC voor 0
S terug trekkend water?? Waterkoeling 11
retrorick Terug van weg geweest (wederom) Introductie: Stel jezelf en jouw PC voor 0
Freddy Guldencoin: De gulden terug, maar in digitale vorm! Hardware & Software 19
J EVGA roept bepaalde reeks GTX 670 Superclocked terug NVIDIA 0
J Turken willen inburgeringsgeld terug Nieuws en Sport 5
ForresT Big Tasty terug bij de Mac Algemene Discussies 91
T waneer is de HAF X terug beschikbaar HighFlow Webshop 1
Vannos weer terug bij het begin Gallery & Build Logs 36
Exeon 'Klassieke bonuslevels keren terug in Street Fighter' Gaming 4
Joren Behouden van pagina bij terug gaan. HighFlow Webshop 3
S cpu klokt niet terug (EIST) Overclocking 7
D Slangen terug... Waterkoeling 7
M Gainward GTX560 TI 2 GB, fullcoverblok verkrijgbaar? Waterkoeling 3
