Lan Party organiseren, DHCP server nodig?
Status
vegettokai
hallo ik ben johan en ben 18 jaar ik ga een lanparty organiseren met n maat van me maar ??
Ik had gelezen dat je een dhcp server nodig had voor ipadressen,maar nu las ik dat dat ook gewoon met n router kan wat kan ik nu t beste doen mvg johan
Exeon
vergeet dit niet btw!!!
WarningsDon't let people plug into each other's power strips, or "daisy chain." It's a disaster waiting to happen.
When dealing with circuit breakers, generators, or distribution boxes, you are dealing with high voltage. High voltage which can kill you! If you are not comfortable with electricity, hire an electrician.
Keep the cables neat and out of the way. Otherwise, someone is bound to trip on them. Consider taping cables down. Bunch groups of them running in the same area together really tight, and put all the slack at either end. Then run strips of strong tape (gaffers/duct) perpendicular. If you're confused about this, speak to a musician friend - it is standard practice to tape wires for sound equipment down, but computer power sources are just as at risk of being pulled out, and rarely do people think to tape them down.
For larger events, liability insurance is required. Even if you have gamers sign a waiver, you cannot make them sign their rights away. A few hundred dollars of liability insurance is better than a million dollar lawsuit.
Unreliable power is the #1 LAN party killer. People will be angry when their computer unrepentently shuts down. Make sure they are plugged into their designated sockets.
The hosts (you!) are responsible for any problems which arise, and they will arise. You may not have much time for gaming, but that is your fate as host.
Unfortunately, theft is a reality at LAN parties.
Have only one entrance and exit, and have someone there watching who comes and goes and with what.
Label anything that is not nailed down, especially as the cost-to-size ratio goes up. (Your thumb drive needs a label, the tables probably not.)
Cheating Is a worry also, so be sure to run an anti-cheat program on the Hosting server.
Status
Freddy Tweakers.net Lan Party? Tweakers Gaming Live Lan Party 19
A [LAN-party] TheGeneration Part 3 18-19-20 oktober 2013 Lan Party 0
M [Lan-Party] The Party 11 Lan Party 100
A [LAN-party] TheGeneration part 2 23-24-25 november 2012 Lan Party 2
M Lan-Party en..... Algemene Discussies 6
D LAN PARTY ZEELAND 4th Edition Lan Party 0
D Lan Party Zeeland 4th Edition komt er aan ! Gaming 0
W Lan Party/Meeting in Vroomshoop Lan Party 11
V Unity II LAN-party 20-21-22 Mei 2011 Lan Party 2
D Lan Party Zeeland 3rd Edition !? Lan Party 1
W Lan Party in Vroomshoop Lan Party 16
D Lan Party Zeeland vernieuwd! Check snel! Lan Party 6
F lan party voor only highflow :D Algemene Discussies 48
Wouter Wat moet je mee nemen voor lan party. Check het hier! Lan Party 78
Wouter The Reality IX - Lan-Party Lan Party 79
A Lan party: Lanfanatics Schipluiden 25-04-08 tm 27-04-08 Gaming 4
C Ranked LAN 4 Nijverdal (17 t/m 19 Feb 2017) Lan Party 0
Aequitis StrikeZero's LAN BOX Gallery & Build Logs 8
gerjanlubbers Foto's Reality 14 LAN Lan Party 5
gerjanlubbers Pink Phantom V2 (Reality Lan) Gallery & Build Logs 22
K Volwaardige 5,25" bay voor Lan Gear Da Box Cases en Modding 1
thiesggb Thieske's Mini-Lan-Bak krijgt waterkoeling Gallery & Build Logs 21
Verderf TTG 4 LAN : Reboot! Lan Party 2
thiesggb LAN GEAR DA BOX update HighFlow Product Suggesties en Nieuws 2
Joren LAN/Meeting Noord Nederland Lan Party 17
W hulp gezocht bij het maken van een Highflow lan Lan Party 22
Blackruby Dual LAN; wat is het nut? Hardware & Software 6
dark viper zwolle [CANCELLED] black lagoon mini lan pctje Verkocht 9
E Eternity-LAN 18 december 2010 Lan Party 8
soppy Lan Cool Cases en Modding 11
w4rlock Lan Gear Da Box 100 HighFlow Product Suggesties en Nieuws 5
Wouter Welke Games Gaan We Spelen Op De Lan? Lan Party 13
C [LAN] Ranked Lan 3, 26 t/m 28 februari 2010 Lan Party 0
Xtrafresh TTG-LAN: The second encounter. 22-24 Jan 2010 Hilversum: 70 MAN Lan Party 52
Killerbee [LAN] LAN-Macht 19 t/m 21 juni *!GRATIS!* Lan Party 120
W [LAN] WittebolX Gaming Lan V1 Gaming 16
Killerbee Lan organiseren? Gaming 72
Source Wat er verbetered kan worden aan Energy Lan Gaming 21
Freddy Live @ Energy Lan Gaming 144
Wouter Lijstje wat jij mee neemt naar lan. Gaming 19
stravinski wie heeft er zin om deel te nemen aan Times-lan? Gaming 4
Wouter Wie gaat er mee naar Energy lan? Gaming 646
M [LAN] Energy lan 2009 powered by Highflow! Lan Party 61
Freddy LAN-Parties! Gaming 76
MrGiorgio Het grote "The Party 18" topic Lan Party 176
MrGiorgio The Party 18 of ..... Lan Party 26
