i7 950 & EVGA X58 SLI
Vannos
upgrading.......
heey,
Vandaag de pc aangeslingert en geinstalleerd vond het tijd voor wat oc op die cpu,
Maar ben er een tijd niet mee bezig geweest dus kan nu wel wat tips en hulp gebruiken.
hier volgende setting.
CPU:
Intelspeedstep: disabled
CxE function: disabled
Execute disable bit: enabled
Virtualization technology: Disabled
Intel HT technology: enabled
QPI: control settings enabled
QPI: link fast mode: enabled
Qpi frequency selection: auto
CPU clock ratio: 20x kan tot 23x
CPU host frequency (mhz) 175
MCH strap: auto
Cpu uncore Freq: Auto
Cpu clock skew: 0ps
Spread spectrum: Disabled
PCIE freQ 100
OC recovery Enabled
turbo Disabled
hoop dat jullie me kunnen helpen :D
Dit zijn mijn settingen @4945 :D
MB - Asus Rampage 2 Extreme
CPU - W3540
RAM - Corsair 3gb 1866
AI overclock - manual
OC from CPU level up - auto
OC from Memory level up - manual
CPU Ratio setting - 23
CPU configuration
CPU Ratio Setting - 23
C1E Support - disable
Hardware prefetcher - disable
Adjacent Cache line prefetcher - disable
Intel Virtualization tech - enable
CPU TM Function - enable
Execute Disabled bit - disabled
Intel HT Technology - disable
Active Processor Cores - 2
A20M - enable
Intel Speedstep tech - disable
Intel Turbo Mode tech - (Not shown if Speedstep is disabled)
Intel C-STATE tech - disabled
BCLK frequency - 215
PCIE frequency - 111
DRAM frequency - DDR3 1075MHz
UCLK frequency - 4300MHz
QPI frequency - auto
Dram timing control
1st iformation - Insert Timings Here in 9-9-9-24 -1T
2nd information - Insert Timings Here in X-X-X-XX -X-X-Xformat
3rd information - Insert Timings Here in X-X-X-XX-X-X-X format
EPU II phase control - full phase
Load-line calibration - enable
CPU differential amplitude - auto
Extreme OV - enable
Cpu voltage - 1.55v
CPU PLL voltage - 1.9v
QPI-Dram voltage - 1.53v
IOH voltage - 1.45
IOH PCIE voltage - auto
ICH voltage- auto
ICH PCIE voltage - auto
DRAM Bus voltage - 1.67v
DRAM REF voltage - auto
Debug mode - string
Keyboard TeakIt comtrol - disabled
CPU spread spectrum - disabled
PCIE spectrum - auto
CPU clock skew - auto
IOH clock skew - auto
oke hier gaat het mis.
Cpu clock 23x
cpu freq 193
Mch strap auto
cpu uncore auto
cpu clock skew
mem speed 1160mhz
vcore 1.36v
vtt =25mv
pll 1.920v
dim 1.650 v
qpi pll 1.125v
ioh vcore 1.125
als ik de freqentie op 194 zet start hij niet door !
zet je mch strap net onder de snelheid van je ram en uncore gewoon het dubbele, laagst dus. het is beter om dit vast te zetten dan auto heb ik ervaren. zeker op hogere overclocks.
pll op 1.8, werkt het beste
S [Waterkoeling] 950 Euro, 4770K met 780GTX in SLI Advies Waterkoeling Setup 1
J [Waterkoeling] €400-500 Core i7 950 + GTX 770 Advies Waterkoeling Setup 1
F [waterkoeling] €600, i7 950, 2x GTX560 (first time) Advies Waterkoeling Setup 12
Viepert [VERKOCHT] i7-950 / Asus Rampage 3 Extreme / Corsair 6Gb Verkocht 6
Fryslanboy [Animocheck] Intel i7 950, ASUS Rampage III Extreme, 6GB Dom GT RAM, Gesloten 6
tarbax 480€, i7-950 OC, GTX480 OC, Rampage 3 EX Advies Waterkoeling Setup 11
Fryslanboy [Waterkoeling] Advies over samenstelling WC systeem (i7 950, REX3, HAF X) Advies Waterkoeling Setup 9
H i7 920 en 950 Gesloten 4
O [Waterkoeling] REIII (fullcover), i7 950, 2x GTX580 en 6x 6x DDR3 Dominator Advies Waterkoeling Setup 8
J OC i7 950 zit vast Overclocking 83
Viepert i7 950 + REX3 + 5970, nieuwe setup gemaakt voor WC Advies Waterkoeling Setup 37
H i7 950 OC en temps Overclocking 21
H [Waterkoeling] i7 950 + GPU's Advies Waterkoeling Setup 2
Viepert Overclock gids voor i7 950 + REX III Overclocking 28
N Mogelijkheden setje i7 950 Advies Waterkoeling Setup 12
Blackruby Core i7 950 en 975 ondersteunen 1600MHz RAM Hardware & Software 1
Jason EK-Quantum Vector EVGA XC3 RTX 3080/3090 D-RGB HighFlow Product Suggesties en Nieuws 0
Sp33dFr34k [TKA] EVGA GTX780 Superclocked met EK WC block Verkocht 0
Marc Laenen EVGA 980Ti ... NVIDIA 3
arwin74 EVGA power link Gevonden 0
X EVGA gtx980 backplate HighFlow Product Suggesties en Nieuws 9
G Evga hadron (hydro) Cases en Modding 1
V [Waterkoeling] i7-5930K-, Socket 2011-3, Rampage V, EVGA GeForce GTX980, Obsidian900 Advies Waterkoeling Setup 13
Tath Bitspower EVGA GTX 970 Supercloked VGa Card HighFlow Product Suggesties en Nieuws 0
stigma [VERKOCHT] EVGA GeForce GTX 780 Ti 3GB Verkocht 14
boefmans [CLOSED]Evga gtx580 sli Gesloten 1
arwin74 [CLOSED]Evga z77 ftw + 3570k Gesloten 2
Hightower evga sli bridge HighFlow Product Suggesties en Nieuws 11
reclamations [VERKOCHT] EVGA gtx680 Verkocht 4
M [CLOSED]EVGA GTX 580 Superclocked 1.5GB SLI + EK WB Fullcovers Gesloten 2
N [Waterkoeling] 700€ ,I7 4470K, 2x EVGA 770 GTX, Asus Maximus VI Hero, Crhr Vengeance Advies Waterkoeling Setup 23
reclamations [Gezocht] EVGA 680 blackplate Gevonden 1
K [CLOSED]Animo 3x evga 580 + wc blocks Gesloten 6
Sw333t [CLOSED] EVGA GeForce GTX 680+ 4GB w/Backplate Gesloten 3
Hightower psu tagan piperock 800watt genoeg voor de evga 770 sc gtx Electronica 4
Aequitis [VERKOCHT] 3x EVGA GTX 580 Hydrocopper 2 Verkocht 12
Hightower past ekfc gtx 680 op een evga gtx660ti ftw? Waterkoeling 2
