GPU/CPU, 540x180 Rad, Silverstone Raven 02
xciter
Hi All,
Ever since I first started building PCs I have always preferred performance over function and noise. Getting older, however, presents a new unique perspective where new and unexpected things annoy you easily. Since I am beginning to be annoyed by the noise the Desktop produces I am considering replacing all of the cooling and PSU with something better. I am happy with the performance, but the noise.. the noise is killing me.
PC relevant hardware list:
Intel 3770K 4.6GHz@1.312v currently
EVGA 980Ti SuperClocked@1450 Core with power modded bios.
The case is(and going to be until the platstic falls apart!): Silverstone Raven 02
Notes:
The case comes stock with 3 180mm FANS, which are currently replaced with some 120mm Noctua fans. Effectively what I have to work with is roughly 195x600mm base and a single 120x120mm slot on the top. Radiator + Fans bottom should not be taller than 65mm. There is plenty of headroom. So with these measurements in mind, I have formulated a plan.
Needed:
1. Get a big ass radiator(like 540x180mm), with a possible backup of a fat 120x120mm, if there is not enough dissipation capacity.
2. Get quiet 180x180mm FAN that spin real slow.
3. Waterblock for CPU
4. Waterblock for GPU
5. New PSU, as the one I have is noisy at all power levels.
6. Somehow mount/hide the pump+waterblock assembly where the 3.5inch drivers would go, as I have 0 of them occupied.
7. Drill a hole on top of the case and install a fitting for easy filling of the system.
8. Drill a hole on bottom right corner of the case for easy flushing onf the system.
9. Fan/Pump controll open to suggestions. Currently 4 fans are contolled by a Scythe thingie with temp sensors(but no auto controll).
Optional:
10. Replace side panel with a new plexiglass or tempered glass piece, as this one has scratches from previous owner of the case
11. Somehow refurbish or re-pain the top plastic(power buttons etc)
12. Re-paint case(eventually).
So following this easy 12 step program(pun intended) I came up with the following parts list:
  1. EK 540 Radiator2
  2. Phobia 180mm 700RPM Fan1
  3. Alphacool XP3 CPU Block1
  4. Alphacool 980Ti GPU Block
  5. Corsair RM750x
Still wondering about soft vs. hard tubing and its size (inner / outer diameter). Larger means more flow, but also more liquid for the pump to push. Also not sure what the difference is between the different fin layouts. Some other ideas would be to mount a reservoir flat in the top 3.5 inch slot and have the pump lower, so it can be cooled by fan on the bottom.
You got a good plan :)
If you think soft tubing is also pretty to look at, go for soft tubing, much easier to build (and maintain) and cheaper and less tools needed.
You could buy a small reservoir+pump combination or a DDC pump with these small reservoitops:
https://www.highflow.nl/watercoolin...cool-laing-ddc-reservoir-top-combo-rev.2.html
https://www.highflow.nl/watercoolin...ops/ddc-tops/ek-ddc-x-res-100-csq-acetal.html
https://www.highflow.nl/watercoolin...p35x-reservoir-with-2-inlet-ports-rev.2b.html
X [TKA Diversen] fittings, CPU en gratis GPU blocks (GTX580) Verkocht 1
X [waardebepaling] fittings, CPU en GPU blocks Gesloten 4
R [Waterkoeling] €1500 CPU + 2x GPU (Mogelijk 3e gpu toekomst) Advies Waterkoeling Setup 23
R [Waterkoeling €500-600] CPU + GPU Advies Waterkoeling Setup 3
G [Waterkoeling] CPU I7-2600k / GPU R9 290 Advies Waterkoeling Setup 50
Heineken [Waterkoeling] GPU: GTX 780 CPU: i7 4790K Advies Waterkoeling Setup 43
M watercooling 600eu max gpu + cpu block? Advies Waterkoeling Setup 1
WiSK Lori Lemaris (FT03-mini CPU+GPU) Gallery & Build Logs 95
U waterkoeling voor cpu en gpu Advies Waterkoeling Setup 20
canonchiel Nieuwe cpu gpu loop Waterkoeling 18
T Welke koelpastas voor CPU/GPU? Waterkoeling 2
stigma 2 gpu's + 1 CPU ...maar welke radiators?? Advies Waterkoeling Setup 14
canonchiel Watercooling aanschaffen cpu later uitbereidbaar voor gpu Advies Waterkoeling Setup 14
JeanPaul [VERKOCHT] MEGA OPRUIMING , Sr-2 ,cpu's , ssd's ,hdd's, geheugen,gpu ect. Verkocht 18
Lqd [REFUSED] CPU + Cooler, Mobo + Cooler, Mem + Cooler, GPU + Cooler +res +fittingen Verkocht 11
ForresT Phase Change Cpu/Gpu Block Overige Koeling 12
B [REFUSED]EK Supreme CPU+GPU - Enzotech NB - XSPC Pomp/res - 360 rad - Nieuw Verkocht 12
I advies over grootte radiator voor koeling cpu en gpu overclocked Advies Waterkoeling Setup 18
H Vraagje over 'HighFlow CPU + GPU Set' (van highflow.nl) Waterkoeling 3
T LOOP: CPU met of zonder GPU('s) Waterkoeling 7
H Advies/Controle waterkoeling CPU, GPU, HDD Advies Waterkoeling Setup 4
T [EUR 400][CPU(Q9550), GPU(4850x2)] Advies Waterkoeling Setup 15
D [400 euro] Waterkoeling setup voor i7 CPU en 8800GT GPU Advies Waterkoeling Setup 2
Dutchie beginners vragen deel 99 i7 920, evga 58, cpu only later gpu Advies Waterkoeling Setup 8
J Advies m.b.t. Kast gevraagd (waterkoeling: cpu/gpu/hdd) Cases en Modding 22
A Cpu+nb+ram+gpu => loops apart of niet? Waterkoeling 25
R Watercooling CPU+GPU Waterkoeling 2
C Barstje in GPU block Waterkoeling 2
