barfastic
-UPDATE-
So, i was thinking of how to make it so, that when i want to change a peice of hardware, i could make it as easy as possible. Everyone who has ahd watercooling in the past i am sure knows what a @@@@@@@ it is to add and remove hardware!
So i got to brainstorming and came up with an idea.
I attached the pumps vertically to the radiators on the inside using some small metal panels.
This way, the entire bottom tray can slide in and out of the bench table, without me having to take apart the watercooling loop
Here you can see the metal plate in place. i am going to cut it so it doesnt block too much air coming out of the radiator.
and here is a total shot of the back side, with all 4 pumps mounted on each radiator
but do you see anything strange?
What do we have here?
2 screws???? hmmmmm.....
I had to find my SSD's a new home because the front panel is already filled with HDDS and Fan controllers, etc...
Thats it for now... more soon
I know, i know.... i have to sleeve, but im looking for a new power supply, and until i find it you guys will ahve to put up with naked cables
