EK Coolstream PE radiators
WiSK
Naam producten
EK-CoolStream PE 120
EK-CoolStream PE 240
EK-CoolStream PE 360
EK-CoolStream PE 480
Naam fabrikant
EKWB
Omschrijving product
EK-CoolStream PE is a high-performance computer water-cooling radiator which combines EK's unique CSQ design with latest radiator core engine. Built for 120mm fans, these radiators are optimized for maximum heat dissipation across entire fan operational range thus delivering exceptional performance at both low- and high airflow operation.
EK assured quality level, optimal price-performance ratio and unique minimalistic design make these EK-CoolStream PE series radiators a perfect choice for any computer water cooled system.
This radiator offers best cooling capacity in the 40mm thick radiator class: Double stack copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum. Radiator shrouds are tapped with UNC 6-32 threads on both sides to enable push-pull fan installation to even further increase the cooling performance.
This product features two recessed G1/4 threaded ports with pre-installed extenders to allow any G1/4 threaded fitting to be used. EK recommends EK-CSQ series compression fittings.
Technical details:
Material:
- Copper fins
- 90% copper tubing (H90)
- Brass chambers
- Aluminum housing
Dimensions: 160 x 130 x 38mm (L x W x H)
Weight: 0.53kg
Liquid Capacity: ~130mL
FPI: 38
Port threads: 2x G1/4
Fan compatibility: any standard size 120x120x25mm fan; UNC 6-32 thread tapping
Pressure tested: 1bar(g)
Enclosed:
- EK-CoolStream PE series radiator /w pre-installed G1/4 extenders
- flat-head UNC 6-32 screws (l=30mm)
- flat-head UNC 6-32 screws (l=5mm)
Link
EK-CoolStream PE 120 (Single) - Radiators - Radiators, Fans & Accessories
EK-CoolStream PE 240 (Dual) - Radiators - Radiators, Fans & Accessories
EK-CoolStream PE 360 (Triple) - Radiators - Radiators, Fans & Accessories
EK-CoolStream PE 480 (Quad) - Radiators - Radiators, Fans & Accessories
Foto's
Added after 40 minutes:
(was iets vergeten:)
Hoi Freddy, kunnen deze rads in de winkel? Ik wil een PE120 en een PE240 bestellen. Alvast dank :)
Freddy EK-CoolStream WE 180, 360 (2x 180) en 540 (3x 180) radiatoren! HighFlow Product Suggesties en Nieuws 0
P [VERKOCHT] EK-CoolStream RAD XT (240) Verkocht 4
P [VERKOCHT] EK-CoolStream RAD XT (360) Verkocht 4
S [IN-ACTIVE] 2x EK-CoolStream RAD XT 360 Verkocht 8
H [GEZOCHT] EK-CoolStream RAD XT (120),10MM (3/8 ID - 1/2 OD) EK-PSC Schroeffitting Gevonden 2
canonchiel [VERKOCHT] EK-CoolStream RAD XT 120 Verkocht 1
canonchiel [IN-ACTIVE] EK-CoolStream RAD XTX 360 Verkocht 0
Arniebomba [VERKOCHT] EK CoolStream XTX 360 Verkocht 1
l3p [VERKOCHT] Diverse EKWB CoolStream XT Radiator Verkocht 1
Cygnitr0n [GEVONDEN] EK-CoolStream RAD XT (240) Gevonden 4
R Welk blok op Club3d 6950 CoolStream 2GB Waterkoeling 4
arwin74 [VERKOCHT] EK-CoolStream RAD XT 360 Verkocht 11
arwin74 [VERKOCHT] EK-CoolStream RAD XT 360 Verkocht 4
D EKWB Quantum Surface Radiators HighFlow Product Suggesties en Nieuws 3
Wasmachineman_NL Hardware Labs GTX radiators in ongewone maten (80/160 en 92/184mm) HighFlow Product Suggesties en Nieuws 1
J 2 radiators Waterkoeling 20
Jason Magicool 240S & 360S G2 Ultra Radiators HighFlow Product Suggesties en Nieuws 0
Ubbidude Radiators schoon krijgen.... Waterkoeling 2
L Hardwarelabs Black ICE GTS Radiators HighFlow Product Suggesties en Nieuws 2
Freddy Bitspower Leviathan Radiators HighFlow Product Suggesties en Nieuws 0
ForresT The Black Ice Nemesis 140GTS, 280GTS, SR2 etc. Radiators HighFlow Product Suggesties en Nieuws 8
stefan787 hoeveel radiators?? Waterkoeling 4
Sw333t Koolance HX-XC Radiators HighFlow Product Suggesties en Nieuws 1
bundymania [Bundymania User Review] 4x 1080 Monster Radiators [English Version] HighFlow Product Reviews 0
stigma 2 gpu's + 1 CPU ...maar welke radiators?? Advies Waterkoeling Setup 14
zat0x 2 radiators in 1 loop ? Waterkoeling 3
A [IN-ACTIVE] Diverse waterkoeling: blokken, fittings, radiators, pomp en nog wat Verkocht 31
coolfris Nieuwe AquaComputer radiators: airplex modularity system HighFlow Product Suggesties en Nieuws 18
Sw333t 80mm radiators (dual 40mm) HighFlow Product Suggesties en Nieuws 2
P hoeveel en welke radiators Advies Waterkoeling Setup 3
Oli4v How to Presure Test@home (radiators) Waterkoeling 2
bundymania SIZE MATTERS: Radiators for 140mm Fans - Roundup HighFlow Product Reviews 12
bundymania REVIEW: TFC Monsta + 4 other Radiators HighFlow Product Reviews 9
Robin Verschil tussen goedkopere en duurder radiators Waterkoeling 7
MrGiorgio Airflow bij 2 radiators Waterkoeling 40
