EK-BAY SINGLE RES - Acetal
karl-may
EK-BAY SINGLE Reservoir - Acetal is a simple, compact yet very efficient water reservoir. Reservoir is made of quality POM Acetal, covered by a 5mm thick acrylic glass. Reservoir features special anti-vortex acrylic insert which effectively prevents air bubbles from re-entering the loop. As a result high flow rates of up to 250L/h (1GPM) are possible with this reservoir. Reservoir features G3/8 threaded filling port, an appropriate plug is enclosed. Reservoir fits in majority of computer chassis and occupies only a single 5.25" drive bay. No boring or sawing is necessary. This reservoir is fully air- and waterproof once closed with the enclosed plugs therefore no water can evaporate.
Features:
- Appropriate for flow rates of up to ~ 250L/h (1,1GPM)
- Fits in single 5.25" drive bay cage
- Monitor your water coolant level
- Easy installation
Specifications:
- main body size: 145x40x60 mm (LxHxD)
- total volume: ~ 170 mL
- port threading: G1/4" x 3
- filling port: G3/8"
- main reservoir material: POM Acetal (black)
- includes needed Allen keys (6mm and 2mm) and plugs (1x G1/4", 1x G3/8")
Zwart
Wit
ik heb er geen nodig, maar is wel leuk voor het assortiment van Highflow
R XS-PC X2O 200 Single Bay Reservoir Pump HighFlow Product Suggesties en Nieuws 2
arwin74 [VERKOCHT] XSPC Single 5.25 Bay Reservoir Verkocht 4
Craven Single bay 5.25" koeler met HDD mount? HighFlow Product Suggesties en Nieuws 6
M single bay reservoir met 2 x inlet en 2 x outlet HighFlow Product Suggesties en Nieuws 7
P Welke Dual bay reservoir met pomp? Advies Waterkoeling Setup 5
Vannos [VERKOCHT] 1xLaing DDC-1 MCP35 /1x Bitspower 5.25 Bay Reservoir Black Verkocht 3
K 300R 5.25" bay cover, black (Corsair) HighFlow Product Suggesties en Nieuws 3
Sw333t Silverstone SST-FP58S 5.25 Slim ODD and 2.5 HDD Bay Silver HighFlow Product Suggesties en Nieuws 2
Aequitis [IN-ACTIVE] Bay res, Chipset block, Res, Rad, Fans Verkocht 11
Aequitis [REFUSED] Bay Res, Chipset block, Res Verkocht 2
Sw333t XSPC Dual 5.25" Bay Reservoir - Black - Ball Front (BR525DBW) HighFlow Product Suggesties en Nieuws 2
M Bay res + Tube res Waterkoeling 3
D un designs rad bracket voor 5.25 inch bay HighFlow Product Suggesties en Nieuws 3
G Scythe 5,25 to 3,5 and 2,5 inch bay rafter HighFlow Product Suggesties en Nieuws 6
K Volwaardige 5,25" bay voor Lan Gear Da Box Cases en Modding 1
E X2O 750 Dual bay pump/res genoeg voor 240 + 360 radiator Waterkoeling 2
D 5.25" bay intake ventilator Corsair Graphite 600T - opties? Cases en Modding 8
R Swiftech Maelstrom-35X 5.25 Dual Bay Reservoir with 2x MCP35X housing HighFlow Product Suggesties en Nieuws 6
volcom xspc x2o 200 bay en pump reservoir Waterkoeling 4
Freddy DangerDen Crystal Reservoir Dual 5.25 Bay Reservoir RES-211 HighFlow Product Suggesties en Nieuws 3
arwin74 [IN-ACTIVE] Cisco NSS4000 4-bay Gigabit Storage System Chassis Verkocht 0
B [VERKOCHT] EK-BAY SPIN Reservoir - Acetal Verkocht 5
Sw333t Bay producten en hardware set HighFlow Product Suggesties en Nieuws 8
B Cooler Master HAF Bay cover Cases en Modding 12
T [VERKOCHT] X2O 750 Dual 5.25” Bay Reservoir Pump Verkocht 2
arwin74 [CANCELLED] Cisco NSS4000 4-bay Gigabit Storage System Chassis Verkocht 14
Viepert [VERKOCHT] EK-BAY SPIN Reservoir - Acetal Verkocht 0
T 800D sata bay ? Cases en Modding 4
Luculenus [IN-ACTIVE] 2x MCP655 met Koolance RP-452X2 rev 2.0 dual bay reservoir Verkocht 7
S Zelfbouw! 5.25 inch D5 bay top/reservoir Gallery & Build Logs 11
J [IN-ACTIVE] EK-BAY Spin RES DUAL Loop en Danger Den Reservoir Verkocht 4
R [VERKOCHT] EK Supreme, 2x 120mm rad, bay res/pomp Verkocht 5
bundymania [User Review] English Version: Primochill Myriad Dual Bay Reservoir D5 - Clear HighFlow Product Reviews 0
bundymania [User Review] Ausgleichsbehälter: Primochill Myriad Dual Bay Reservoir D5 - Clear HighFlow Product Reviews 1
E Scythe Kama Bay HighFlow Product Suggesties en Nieuws 7
boefmans twee pompen in een dual bay reservoir Waterkoeling 14
Sw333t [VERKOCHT] Radiator in 5.25 bay Montage Brackets Verkocht 6
A Bay reservoirs Advies Waterkoeling Setup 1
Crosshair 4 Extreme-666 past een XSPC UV Blue Dual 5.25" Bay Reservoir in een Cooler Master CM690 II Advanced Cases en Modding 3
K vraag over XSPC : dual 5.25´ acrylic bay reservoir Waterkoeling 3
C xspc Bay Temperature Sensor Frame HighFlow Product Suggesties en Nieuws 3
