Corsair Dominator GTX confirmed as Worlds Fastest XMP-certified memory
Colossus
[HF]
FREMONT, California, January 21, 2010 — Corsair, a worldwide leader in high-performance computer and flash memory products, today announced that the Dominator GTX1 ultra-high performance DDR3 memory module (CMGTX1) has passed Intel’s XMP-Ready certification at the blistering speed of 2333MHz, surpassing Corsair’s 2000MHz modules as the fastest XMP-certified memory in the world.
Corsair Dominator GTX modules are individually hand-screened and tested to ensure unmatched performance. They are designed specifically for enthusiasts and overclockers who want to achieve the highest performance possible, and to break benchmark world records.
Intel’s engineers awarded the XMP-Ready certification to 2 x 2GB Corsair CMGTX1 modules running at the incredible frequency of 2333MHz using low timings of 9-11-9-27 at a voltage of just 1.65V. The test platform was a Gigabyte™ GA-P55A-UD4P motherboard. The successful XMP certification is a testament to the performance capabilities as well as the stability of both the memory and the target platform.
“Building the fastest memory for extreme overclockers and enthusiasts requires considerable engineering expertise, combined with a unique understanding of the complexities of overclocking,” said Kevin Conley, VP of Engineering at Corsair. “Intel is one of the most meticulous and sophisticated technology companies in the world, and so achieving XMP-Ready certification at the astonishing frequency of 2333MHz once again clearly demonstrates Corsair’s performance leadership.”
Corsair Dominator GTX1 modules are individually screened and tested on multiple high-performance Intel P55 chipset platforms. In addition to the XMP-Ready certification at a frequency of 2333MHz, they are guaranteed by Corsair to operate at up to 2400MHz at timings of 9-11-9-27 at 1.65V.
Corsair Dominator GTX modules are available exclusively from Corsair’s Online Store. They utilize Corsair's patented DHX+ heatsink and are supplied with extra-tall cooling fins to maximize heat dissipation. They are sold as a single module, allowing enthusiasts to simply buy the number of modules they require. Corsair recommends using the GT Airflow fan with tall mounting brackets, also available from the Corsair Online Store (part number CMXAF2 GTL).
As Corsair Dominator GTX1 modules are screened by hand, in multiple passes, at Corsair's lab in Fremont, California, availability is extremely limited and is on a first come, first served basis only.
Bron: Corsair Dominator GTX confirmed as Worlds Fastest XMP-certified memory - HardwareHeaven.com
Rooneys [VERKOCHT] 2x4GB Corsair Dominator GT CMT16GX3M4X2133C9 Verkocht 1
bundymania [Bundymania User Review] Alphacool D-RAM Cooler X4 (für Corsair Dominator™ RAM) HighFlow Product Reviews 0
l3p [VERKOCHT] Corsair Dominator GT 3 x 2 GB DDR3-2000 CL7 (Elpida) Verkocht 1
l3p [VERKOCHT] 16GB Corsair Dominator GT 2133Mhz C9 modded en incl EK Plexi block Verkocht 1
Wouter [Gezocht] Corsair Dominator TR3X6G1600C8D Gevonden 0
Celly MSI GD65 + Scythe Mugen 3 + Corsair Dominator Hardware & Software 0
arwin74 [VERKOCHT] Corsair DOMINATOR-GT 16GB Verkocht 1
3 [VERKOCHT] Corsair DOMINATOR-GT 6GB Verkocht 5
Sanders [IN-ACTIVE] Corsair Dominator GT 2000 Mhz 12 Gb set Verkocht 0
Stephan---pro [IN-ACTIVE] Corsair dominator gt headspreader Gevonden 3
Viepert [IN-ACTIVE] Corsair Dominator 6GB DDR3-1600 Tri-kit icl. Dominator Airflow Verkocht 1
sir serial [VERKOCHT] Corsair Dominator GT Airflowfan Verkocht 31
sir serial [VERKOCHT] Corsair Dominator GT CMT8GX3M4A1866C9 Verkocht 5
l3p [VERKOCHT] Corsair Dominator GT CMT8GX3M4A1866C9 Quadkit Verkocht 4
B 6x4098MB Corsair XMS3 Dominator DDR3 1600MHz HighFlow Product Suggesties en Nieuws 9
Duriel [VERKOCHT] Corsair Dominator GT CMG4GX3M2A1600C7 Verkocht 1
Killerbee [VERKOCHT] Intel i7 860, Asus Maximus III Gene & Corsair Dominator GT 4GB Verkocht 23
arwin74 Corsair Dominator CMP8GX3M4A1600C8 HighFlow Product Suggesties en Nieuws 1
Fryslanboy [IN-ACTIVE] Corsair Dominator GT Heatspreaders Gevonden 11
Vissa [VERKOCHT] 6GB DDR3 Corsair Dominator GT's 1600Mhz CL7 Verkocht 1
Edtje [VERKOCHT] 6GB DDR3 Corsair Dominator GT 1866 Verkocht 2
vincent EK Corsair Dominator GT RAM blok HighFlow Product Suggesties en Nieuws 12
Garrett [VERKOCHT] Corsair Dominator GT CMT6GX3M3A2000C8 3x2GB Verkocht 2
Sanders Corsair Dominator GT 4GB DDR3-2000 CL8 kit HighFlow Product Suggesties en Nieuws 7
l3p [VERKOCHT] Corsair Dominator GT CMT6GX3M3A 2000 C8 + Dominator GT Fan Verkocht 5
l3p [VERKOCHT] Corsair Dominator GT CMXAF2 GTL Airflow cooling fan Verkocht 4
l3p [TKA-6GB-DDR3] Corsair Dominator TR3X6G1600C8D Verkocht 3
l3p Corsair Dominator geheugen, welke zal ik nemen? Hardware & Software 30
W Waterkoeling €800, i7 930, 2 x HD5870, Corsair Dominator GT 6GB Advies Waterkoeling Setup 12
Colossus Corsair Dominator RAM Waterblokken / Koelblokken Waterkoeling 33
RRPhantom OCZ Reaper PC3-16000 vs OCZ Reaper PC3-12800 vs Corsair Dominator PC3-12800, welke? Hardware & Software 36
X 60MM Fans, o.a. voor Corsair Dominator MEM cooler HighFlow Product Suggesties en Nieuws 4
ReQuiem Corsair Dominator DDR3 set Hardware & Software 3
