Core I7 CPU koelblokken reviews
Edtje
Highflow Clan Member
Ik weet niet of deze links al zijn gepost maar het leek mij wel handig voor diegene die nog een keuze moeten maken.
I7 Waterblock Mini Review EK Supreme Vs Koolance 350 Vs Swiftech Gtz vsDtek Fusion V2
Hondacity
10-01-2009
XtremeSystems
Informal test results CPU 350 vs Apogee GTZ
Stephen(Swiftech lab)
20-01-2009
XtremeSystems
I7 waterblocks Version2 (Ek Supreme LT | Koolance350 | Dtek Fuzionv2 | Swiftech GTz)
XtremeSystems
25-02-2009
Hondacity
[User-Review] Watercool Heatkiller 3.0 LT vs. Koolance CPU-350AT
camps
25-02-2009
Forum de Luxx
I7 Waterblocks Version3
Hondacity
13-03-2009
XtremeSystems
Results(best 3 for each block out of 5 or 30+ mounts)
Test report Apogee GTZ vs. Koolance 350 vs. HeatKiller 3.0
02-04-2009
RRTech
*(Volgende vijf testen zijn niet chronologisch in deze review opsomming geplaatst. het zijn namelijk geen vijf verschillende round-ups, maar elke keer worden er weer een aantal blokjes toegevoegd aan de al behaalde test uitslagen.)/*
Waterblocks on i7 part1
HESmelaugh
16-03-2009
RRTech
Waterblocks on i7 part2
HESmelaugh
27-03-2009
RRTech
Waterblocks on i7 part3
HESmelaugh
05-04-2009
RRTech
Waterblocks on i7 - Part 4
HESmelaugh
11-04-2009
RRTech
En zijn laatste van deze serie:
Waterblocks on i7 part5
HESmelaugh
19-05-2009
Here's what we get as an overview, when all the results from the three runs above are averaged out:
HESmelaugh zei:
Conclusion
As always, I want to keep this to a minimum and leave judgement and further speculation up to you.
In my opinion, the HK 3.0 LC is the most remarkable block of this bunch. Not because of it's performance or flowrates alone, but simply because it offers these at such a low price. Way to corner a market, Watercool.
I like the design of the Ybris Eclipse a lot and it's a block where I can imagine many will go for it for the looks, knowing that they won't get top-notch performance out of it. The Niagara is interesting but unfortunately not very good. Time to experiment with new base plates, Alphacool.
The Koolance... great performance, super restrictive. I'm sure speculation will not rest after this test, either.
S1366 CPU Cooler Roundup - 9 models in the test!
bundymania
09-05-2009
hardwareluxx
18-05-2009
XtremeSystems
Note: where “∆” stands for Delta, and is meant as “difference[/QUOTE]
Ik had eerst de Supreme maar toen ik die test zag en zag dattie zo restrictive was heb hem vervangen voor de Heatkiller. Ik heb nu veel meer flow als ervoor!
udate'je ivm de komst van de Swiftech XT:
Maar eerst een kleine aanvulling op het oude:
Grafiekjes van de drie Swiftech testen staan helaas niet meer online. Hier een pdf met de data van de laatste van die drie testjes welke op dit moment nog wel online staan. ;)
Dan nu de nieuwe :)
Swiftech
07-10-2009
Swiftech
Valt me wel op dat de heatkiller in de eerdere testen van Swiftech nagenoeg gelijk presteerde tov de GTZ (zie die pdf met de overgebleven online restanten van die testjes) en dat er nu een verschil van 1.4c is tussen dezelfde blokjes. Natuurlijk zijn het verschillende testen en omstandigheden, maar 1.4c vind ik aardig veel voor waterkoelbegrippen...
8 mounts Swiftech XT vs 8 mounts HK 3.0 all copper
15-10-2009
rge
Overclockers Forums - Powered by vBulletin
mcoffey heeft de Swiftech XT nu ook getest tegenover de koperen heatkiller. Helaas geen grafiekjes, maar omdat hij bekend staat als één van de betere testers hier de quote van zijn bevindingen welke hij op RRtech heeft gepost:
I've tested the XT every which way till Sunday, and I show it 0.7c behind the HK3 with copper top. The internal pin matrix is chewed up with poor inconsistent milling on the XT, and I can see small pits on the the base that appear to come from casting also.
From what I can tell, the XT is no where near as well made as the GTZ was, but does perform better than the GTZ. That much they got right. Another thing, the XT mounting
system doesn't seem to crank the block down any where near as much as the GTZ mounting system did. You can spin the XT screws down easily to the stops, but you almost always has to use a screw driver to crank the GTZ springs down all the way unless you want to remove skin from the finger tips.
That all being said, I test as "best used", not "as sold" on the other blocks with my own preference of springs, mounting pressure and back plates. So maybe that has something to do with the difference I'm seeing in performance from what other have stated.
The XT is a decent performer with one of the best mounting systems available, but I haven't seem one reason to swap a HK3 out for a XT yet based on any performance or workmanship criteria.
andyc
Another thing I forgot to mention, the XT is restrictive as hell. Only about 10% more flow over the KL-350 on my setup, and about 20% less flow than my EK Supreme.
andyc
Wat dat laatste betreft komt i dus wel overeen met Vapor. Hopelijk zal Hesmelaugh en Skinnee de XT ook nog even onder de loep nemen. Het zal dan ook wel weer erg close zijn vermoed ik. :p
stefan787 Intel Core i7 3820 of en andere 2011 socket cpu Gevonden 0
Sw333t [IN-ACTIVE] Pentium Gxxx / Core i3 / i5 cpu (de niet K-modellen), socket 1155 Gevonden 0
R Waterkoeling +/- 250 euro, Alleen CPU (Core i5 2500K) later mogelijk uitbreiden. Advies Waterkoeling Setup 15
Sw333t [Gezocht] Core i3 cpu, mobo + 4gb ram Gevonden 0
F [GEVONDEN]-intel core i7 1366 cpu Gevonden 1
C installatie Cpu waterblock Cuplex Hd Core i7 Waterkoeling 1
S CPU Probe NZXT Sentry Core I7 Waterkoeling 1
S Mijn eerste WC (CPU only) Core I7 965 Waterkoeling 29
W CPU koelblok voor Intel core 2 quad CPU Waterkoeling 4
Bl4ckj4ck666 Thermaltake core p8 tg HighFlow Product Reviews 0
Bl4ckj4ck666 Thermaltake core p8 tg Cases en Modding 2
vincent Morpheus ii core edition HighFlow Product Suggesties en Nieuws 1
T Waterkoeling core p5 Advies Waterkoeling Setup 8
Bas9466 Core xg asus hero 8 Gallery & Build Logs 4
B Tt v21 core Cases en Modding 3
Sw333t [VERKOCHT] HP Pavilion Sleekbook 15-b072ed (Core i3, 8gb ram, 160gb ssd) Verkocht 2
stefan787 [GEVONDEN] Intel core I5 3470k Gevonden 1
Vannos [VERKOCHT] Intel core i7 920 D0 Verkocht 1
J [Waterkoeling] €400-500 Core i7 950 + GTX 770 Advies Waterkoeling Setup 1
R Intel Core i7-4770k Overclocking Overclocking 15
P [Waterkoeling] Intel Core i5 3570K Advies Waterkoeling Setup 12
arwin74 [VERKOCHT] INTEL Core I7 2700k Verkocht 1
3 [IN-ACTIVE] Intel® Core™ i7-975 Processor Extreme Edition Verkocht 5
G [CLOSED] Quad core game pc watercooled Gesloten 2
Zwelgje Avexir Core Series MPOWER HighFlow Product Suggesties en Nieuws 2
WiSK Heatkiller GPU-X3 Core LC HighFlow Product Suggesties en Nieuws 2
M Socket 775 quad core, DFI lanparty x48, Antec 1200 Advies Waterkoeling Setup 2
Johnny Asus Sabertooth / Intel Core i7 3770k HighFlow Product Suggesties en Nieuws 3
T Amd of intel core? Hardware & Software 7
Robin Core i5 2500K VS Core i7 2600K Overclocking 6
Sw333t Intel Core i7 2600K vs Intel Core i7 2700K Overclocking 11
Sw333t [GEVONDEN] Intel Core i5 2500K Boxed Gevonden 1
Johnny [CLOSED] Asus Rampage II Gene, Core i7 920 D0, Club3D 5970 6GB ocz-xtc Gesloten 4
R Intel® Core™ i7-2600K overclocked Overclocking 2
dark viper zwolle Alphacool Cape Fuzion Core 10 Acetal Black HighFlow Product Suggesties en Nieuws 4
X-Tripiot [IN-ACTIVE] Intel core duo e8600 Gevonden 0
Ludwig Core i7 920 D0 OC en temps Overclocking 18
Aequitis [VERKOCHT] GTX260 Core 216 2 stuks ! Verkocht 12
bundymania [User Review] Alphacool Cape Fuzion Core 10 & 30 - Acetal - Black Reservoir HighFlow Product Reviews 1
C [Waterkoeling] €1200, intel core i7 920 @ 3.8GHz, GTX 580 SLI, Gigabyte EX58-UD3R Advies Waterkoeling Setup 13
lauwagie [waterkoeling] Intel Socket 1366 : Core i7-990X en SLI ZT-50303-10M Geforce GTX560 Ti Advies Waterkoeling Setup 108
