Cooler Master HAF 932
With pure innovative strength, Cooler Master, the leader in enthusiast
computer components, has unleashed yet another prevailing arsenal to
compete in the full-tower chassis segment. Proud and robust in its
appearance, the HAF 932 presents its sturdy sentinel housing and
revolutionary High Air Flow structure to enhance and protect any hardware
component that is worthy of the highest performance.
1. The HAF932 features a fully-rugged appearance and is housed in a tough
casing to offer outstanding protection.
2. A rugged HAF932 comes equipped to operate with unparalleled thermal
performance.
3. Patented finger-press buttons for quickly maintaining or upgrading 5.25
inch drive devices.
4. Removable HDD racks and cable management system for better cable
routing and neatness.
- Available Color: Black
- Dimension: (W / H / D) (W)230 x (H)545 x (D)575 mm
- Weight: 13.2 kg
- Material: SECC, Plastic
- Motherboards: Micro-ATX / ATX / E-ATX
- 5.25" Drive Bay: 6 (without the use of exposed 3.5 inch drive bay)
- 3.5" Drive Bay: 5 Hidden 1 Exposed (converted from one 5.25 inch drive bay)
- I/O Panel: USB 2.0 x 4, IEEE1394a x1, eSATA x 1, Mic x 1, Audio x 1
- Cooling System Front : 230x30mm red LED fan x 1, 700 R.P.M, 19 dBA
- Cooling System Side: 230x30mm standard fan x 1, 700rpm, 19dBA
(support 120mm fan x 4)
- Cooling System Top: 230x30mm standard fan x 1, 700 R.P.M, 19dBA
(support 120mm fan x 3 or 120mm x 1 + 230x30mm x 1)
- Cooling System Rear: 140x25mm standard fan x 1, 1200 R.P.M, 17dBA
(support 140mm fan)
- Expansion Slots: 7
- Power Supply: Standard ATX PS2 / EPS 12V (optional)
Maare niet echt mijn type kast :eusa_think:
performance.
inch drive devices.
- Weight: 13.2 kg
(support 140mm fan)
