CM Force 500 Bild
WebTourist
Hi everybody,
I want to introduce you my new MOD CM Special Force 500
1. I made two holes for sata cables
2. I installed SSD frame at the bottom and make a small hole at the right side for HDD
3. I removed this frame to make room for the radiator
That's all :)
CM SPECIAL* FORCE 500 - water cooled custom gaming PC
Hardware information:
Case - Cooler Master FORCE 500 - The Best Budget PC Case
DDR - Corsair Dominator Platinum 16GB DDR3-1866, KIT OF 4
CPU - Intel Core i7-3770K @4.7 Ghz / 1.27 v
Motherboard - Asus Maximus 5 Gene ROG Republic of Gamers
PSU - Corsair HX1050W
2 video cards SLI mode Asus GTX 680 @1300 Mhz / 7000 Mhz
SSD - Intel SSD 330 120 GB
SSD - Intel SSD 335 180 GB
HDD - Western Digital Red 1000GB 7200 64MB
3D Monitor - Asus VG278H 3D
3D glasses - NVIDIA 3D Vision 2 -- Full HD Stereoscopic
Sou headset Asus HS-W1 wireless
OS - Windows 8 64
Liquid Cooling
Ready for Battlefield 4 .... :)
Cooling information:
CPU:
- EK-Supremacy - Nickel - Plexi
GPU:
- 2 x EK-FC680 GTX DCII - Acetal+Nickel CSQ
- 2 x EK-FC680 GTX DCII - Backplate - Black
- EK-FC Bridge DUAL Serial CSQ Plexi
Radiators:
- Black Ice GT Xtreme Lite 240
- Magicool 120 Ultra
Pumps:
- 2 x Alphacool D5-VPP655
Reservoir:
- XSPC Twin D5 Dual Bay Reservoir
Fittings:
- 2 x Alphacool HF 90 G1/4OD 10mm (3/8 ID - 5/8 OD) Chrome
- 5 x Alphacool HF 45 G1/4OD 10mm (3/8 ID - 5/8 OD) - Chrome
- 3 x Alphacool HF G1/4OD 10mm (3/8 ID - 5/8 OD) - Chrome
Coolant:
- Feser One Cooling Fluid - PURE / NO UV - Red
Tube:
- Tygon R3603 - HighFlow - 3/8 ID - 5/8 OD - Clear
Benchmark Tests:
- 3Dmark 11
- 3Dmark FIRE STRIKE
vincent [IN-ACTIVE] logitech driving force GT Verkocht 1
R Corsair Force 3 60GB HighFlow Product Suggesties en Nieuws 6
M Force 3D ATIRadeon HD4670 - GDDR3 1GB/128Bit PCI-E nieuwe cooler Overige Koeling 5
Blackruby Corsair Force HighFlow Product Suggesties en Nieuws 4
J [Waterkoeling] €500 i5 2500K, (GTX970) Advies Waterkoeling Setup 20
R [Waterkoeling €500-600] CPU + GPU Advies Waterkoeling Setup 3
0 [Waterkoeling] €500.-, I5-3570K, 2x GTX 660 Advies Waterkoeling Setup 4
B Waterkoeling i7 3770k 7970top dcu2 corsair 900D ongeveer 500 euro Advies Waterkoeling Setup 40
ProAce Game PC €500, in gedeeltes Hardware & Software 28
D [Waterkoeling] €500 euro, i7-3970X, GTX TITAN Advies Waterkoeling Setup 14
J [Waterkoeling] €400-500 Core i7 950 + GTX 770 Advies Waterkoeling Setup 1
P [Waterkoeling] €300- 500 euro, i7 2600K Advies Waterkoeling Setup 10
K [Waterkoeling] €500 euro, X6 1100T Black Edition, Sapphire Radeon HD 4850 Toxic 512MB Advies Waterkoeling Setup 4
k.3nny [IN-ACTIVE][500-750]15" laptop voor daily. Gevonden 2
E [Waterkoeling] €500 i5 2500k, MSI 460GTX Advies Waterkoeling Setup 6
V 1e Waterkoeling (High-End) Budget 500,- Plan Advies Waterkoeling Setup 36
I [Waterkoeling] €500 euro, i7 2600k Advies Waterkoeling Setup 13
R Waterkoeling, 500 Euro , i7 920, en in toekomst GPU Advies Waterkoeling Setup 25
G my first watercooling. cpu only 500€ Advies Waterkoeling Setup 3
F €500, i5 2500k, 6990 Advies Waterkoeling Setup 18
The_Saviour# Laptop €500/600 gezocht Hardware & Software 7
C WC set, Budget: 500 Intel i7 920/ Asus 5870 Matrix 2GB / Asus P6T6 WS Revolution Advies Waterkoeling Setup 11
P [waterkoeling] €500 ,am2 ,gtx480 Advies Waterkoeling Setup 2
P [Waterkoeling] Budget <500 Advies Waterkoeling Setup 17
O GTX 500/400 Series High-Flow Bracket HighFlow Product Suggesties en Nieuws 3
the_cyberspace [Waterkoeling] +- €500 euro, 2x Intel Xeon E5620, Fractal Design Define XL Advies Waterkoeling Setup 6
N [Waterkoeling] €500, i7 2600K, GTX580 Advies Waterkoeling Setup 2
M [WC +- 500 Euro] i5 2500K + HD6970 - Absolute Stilte Advies Waterkoeling Setup 5
A [GEANNULEERD] 5x 500 GB Seagate Barracuda HDD's Verkocht 7
N [waterkoeling] €500-€700 I7920, 5870,GIGABYTE -EX58-UD5 Advies Waterkoeling Setup 11
B [Waterkoeling] €500 euro, Q6600, NB, SB, Mosfets, 2x EAH6850, CM Storm Sniper (BE) Advies Waterkoeling Setup 7
R [watercooling] 500/600 euro, i5 2500k, ASUS EAH5870, HAF X Advies Waterkoeling Setup 7
Z [waterkoeling]€500,- 2x hd5850, Phenom II X4 965 @3.4 GHz Advies Waterkoeling Setup 68
cederieck [Waterkoeling] €500 euro, Q6600, 6970 meningen en tips Advies Waterkoeling Setup 9
HighSpeed^ Advies Nieuwe PC :D - Budget €500,- Hardware & Software 17
H 1e WC / +- €500 / i7920d0 / 2x XFX 4890 Black Edition (Crossfire) Advies Waterkoeling Setup 27
B [waterkoeling] €500-750: e6550, EN8600GT, 2 x hdd3.5'' Advies Waterkoeling Setup 11
L Eerste Waterkoeling €500 / €200 Advies Waterkoeling Setup 44
H [Waterkoeling] € 500, I7 920, 2x5850 Advies Waterkoeling Setup 6
H mobo/cpu/ram 500 euro max? Hardware & Software 9
