Chieftec MK-35DV Accessory set
Sw333t
I Love my NUC
Hoi Freddy,
Kan jij deze accessoire kit leveren en zo ja, tegen welke prijs en levertermijn?
Naam product:
Naam fabrikant:
Chieftec
Omschrijving product:
The MK35-DV is an accessory set for the Chieftec IX-01B case. If you want to widen the functionality of your IX-01B then this set offers you two perfect optional solutions. At first you have the possibility to add an extra slimline DVD drive, or on the other hand you can increase the storage capacity by adding an extra 3.5" and a 2.5" hard disk drive. It's up to you to decide which option you go for.
Technical data:
Dimension (DxWxH): 216mm x 197mm x 33mm
Weight: 0.6Kg (net)
Material: Metal / Plastic
Special features: Optional accessory set for Mini-ITX Case IX-01B
Scope of delivery: Special extensions cover with two panels (HDD and DVD option) HDD fixing sheet, spacer, connecting plate
Link/URL naar website van de fabrikant + pagina van het product:
MK-35DV
Adviesprijs en eventueel een link naar het productpagina bij andere shops:
Foto's van het product:
