Brook X One SE Adapter for Xbox One/Series S/Series X/Nintendo Switch/PS4/PC
Jason
Met deze kleine adapter / converter kunt u uw Controller op vrijwel elke console gebruiken! Brook X One Adapter SE-controller is perfect compatibel met Xbox Series X / S / One, PlayStation 4, Nintendo Switch en PC. Motion control en 3,5mm microfoon headset worden wederom volledig ondersteund. Meer connectiviteitsinformatie op HighFlow.
Bestel het in de shop:
Jason Brook Wingman XE X360, X1, X Elite 1&2 to PS4 Controller Super Converter Adapter HighFlow Product Suggesties en Nieuws 0
Jason Brook Powerbay Portable and Fast Charging Stand, Docking for Switch, Compatible with Switch and GC Controllers, Support HDMI Output HighFlow Product Suggesties en Nieuws 4
S 5,7,12 V Molex adapter HighFlow Product Suggesties en Nieuws 2
bundymania [Bundymania User Review] Alphacool Eiszapfen Anschlüsse und Adapter in der Übersicht HighFlow Product Reviews 1
A Bitspower G1/4 90-Degree Female to Female Adapter - Matt Black - BP-MB90DIG14 HighFlow Product Suggesties en Nieuws 7
coppercoq EK-PSC Adapter 90° G1/4 Black HighFlow Product Suggesties en Nieuws 1
ProAce [GEVONDEN] Molex > fan adapter Gevonden 1
D EK-PSC Adapter 90° G1/4 Black en 770 GTX Lightening HighFlow Product Suggesties en Nieuws 4
E [IN-ACTIVE] Sitecom Bluetooth 2.0 USB Adapter CN-521 100m Verkocht 2
WiSK Welke kleur is deze fitting/adapter? Waterkoeling 3
WiSK Gelid PWM fan adapter HighFlow Product Suggesties en Nieuws 1
ShadowBumble [VERKOCHT] Asus EAH6870/2DI2S/1GD5 + EK Block + Backplate + MiniDP -> VGA Adapter. Verkocht 4
Thierry Phobya 200mm rad fan adapter HighFlow Product Suggesties en Nieuws 1
7 Cooler Master Internal to External USB 3.0 Adapter HighFlow Product Suggesties en Nieuws 5
Mobomonster XSPC Fillport + M20 adapter Chrome HighFlow Product Suggesties en Nieuws 14
Bullus EK-VGA Supreme HF HD7970 Cu Adapter HighFlow Product Suggesties en Nieuws 13
P EK-adapter fittingen Nickel HighFlow Product Suggesties en Nieuws 2
l3p [VERKOCHT] Innergie mCube Pro Universele adapter/lader Verkocht 1
ben361 Lian Li UC-01 USB 3.0 Adapter HighFlow Product Suggesties en Nieuws 3
Sw333t [VERKOCHT] Asus PCE-N13 802.11b/g/n Wireless PCI-Express Adapter Verkocht 9
G Bitspower black sparkle 30-graden adapter HighFlow Product Suggesties en Nieuws 2
E [Gezocht] Bitspower G1/4 Silver Shiny Rotary 90 Degree ID 1/4 Adapter Gevonden 0
Crosshair 4 Extreme-666 Hardeschijf kloon Adapter van LINDY in assortiment op nemen HighFlow Product Suggesties en Nieuws 4
D EK-PSC Adapter 45° G1/4 Black HighFlow Product Suggesties en Nieuws 2
Fall3n [GEZ][TijdelijkLenen] Male DP To Dvi Adapter of Male DP to VGA Adapter Gevonden 3
S Internal USB 3.0 Adapter bitfenix HighFlow Product Suggesties en Nieuws 19
Sw333t [GEVONDEN] 5.25" to 3,5" adapter van Lian-Li Gevonden 3
Dustyrick PC Chat Adapter Cable HighFlow Product Suggesties en Nieuws 5
Dustyrick PC Chat Adapter Cable Hardware & Software 6
Sw333t [GEANNULEERD] Samsung SN-S082 versie H, IDE/PATA, zwart (met adapter voor in de pc) Verkocht 5
D Bitspower 45° adapter fitting lekt bovenaan Waterkoeling 11
Wizzard22 SATA adapter/verlengstuk met mini rotor HighFlow Product Suggesties en Nieuws 1
dark viper zwolle Adapter, Intel Socket 1156 (CPU-350) HighFlow Product Suggesties en Nieuws 1
M AC-DC adapter Hardware & Software 2
C UV Light 30cm QUAD set: 1 adapter doet het niet = 2 lichten gaan niet aan. Cases en Modding 11
coolfris Bitspower C47 Multi-Link Adapter HighFlow Product Suggesties en Nieuws 26
dopestuff dual psu adapter HighFlow Product Suggesties en Nieuws 2
D 4>3 pin molex adapter HighFlow Product Suggesties en Nieuws 2
