Bitspower Z-Cap I\ II \ III upgrade kits "BRASS" voor de 60 mm reservoirs.
Tath
Well-known member
Bitspower nieuwe "Brass" upgrade kits voor de 60 mm reservoirs.
BP-WTZBC1-TB With G1/4" x1 (Brass Version)
BP-WTZBC2-TB Z-CAP II With G1/4" x3 (Brass Version)
BP-WTZBC3-TB Z-CAP III With G1/4" x2 (Brass Version)
Features:
1. Upgrade application.
2. RoHS Compliant.
Material: Brass.
Color : True Brass.
Specifications:
1. OD. 60MM.
2. Thread : M52
3. G1/4" .
***All Specification Will Be Changed Without Further Notice***
Tath Bitspower Dual / Single D5 Top Upgrade Kit 150 Kit 150 (Black POM Cap) HighFlow Product Suggesties en Nieuws 1
Bl4ckj4ck666 Bitspower waterblock nvidia rtx3090fe Waterkoeling 1
Jason Bitspower BIG SALE% ­čĆĚ´ŞĆ HighFlow Product Suggesties en Nieuws 0
G FS: Bitspower, EKWB, Koolance en Barrow Fittingen en koppelingen Koeling 0
