Bitspower News!
BP-DDCTOPUK250AC-CLCL--1024X768-1.jpgBP-DDCTOPUK250AC-CLCL--1024X768-2.jpgBP-DDCTOPUK250AC-CLCL--1024X768-3.jpgBP-DDCTOPUK250AC-CLCL--1024X768-4.jpg
BP-DDCTOPUK250AC-CLCL Bitspower DDC TOP Upgrade Kit 250 (Acrylic Version)
Features:
1. Easy and Use.
2. Design For Bitspower DDC TOP With Reservoir Application.
3. Only Compatible With Bitspower Z-Multi / Z-tube / Z Series.
4. Made Of Hi-Quality Acrylic.
5. RoHS Compliant.
Color : Clear.
Thread : G1/4” x 2
Included :
1. BP-WTZACC1-CL x 1PCS.
2. BP-WTZACT250-CL x 1PCS.
3. DDC Z-Tube Adapter-CL x 1 PCS
4. Screw x 1Set.
***All Specification Will Be Changed Without Further Notice***
Here are several different combinations.
Bitspower DDC TOP Upgrade Kit 150 (Acrylic or POM Version)
Bitspower Taiwan On-Line Shop
Bitspower DDC TOP Upgrade Kit 250 (Acrylic or POM Version)
Below is the DDC TOP which could match with Bitspower DDC TOP Upgrade Kit.
It sells singly, and is not included in the Bitspower DDC TOP Upgrade Kit.
DDC TOP (Acrylic or POM Version)
DDC TOP Acrylic Version [BP-DDCTAC-CL] : Bitspower Taiwan On-Line Shop
DDC TOP POM Version [BP-DDCTP-BK] : Bitspower Taiwan On-Line Shop
Die is wel kicken he! :)
VuXX Bitspower-block voor GTX470/480 news Waterkoeling 7
J Bitspower None Chamfer Brass Hard Tubing OD16MM Shining Silver Waterkoeling 4
