BitFenix Spectre Pro Led Fan
Kristof Arens
Hey Freddy, zou het mogelijk zijn om te geraken aan deze fans (liefst de rode in formaat 200mm)? :)
Dimensions (mm) 200x200x25mm
Current (A) 0.33A ±10%
Speed (RPM) 900 RPM ±10%
Air Flow (CFM) 148.72 CFM ±10%
Air Pressure (mmH2O) 1.26 mmH2O
Noise (dB-A) 27.5 dB(A)
l3p [VERKOCHT] 5 x BitFenix Spectre Pro Led Red 120mm Verkocht 4
R Bitfenix Spectre pro led fans - White HighFlow Product Suggesties en Nieuws 2
J BitFenix Spectre PRO 230mm Fan/ White led HighFlow Product Suggesties en Nieuws 1
Thierry Bitfenix 200mm Spectre Pro LED White HighFlow Product Suggesties en Nieuws 2
Sw333t Bitfenix spectre™ all white - 200mm HighFlow Product Suggesties en Nieuws 8
volcom Bitfenix prodigy m windowed side panel zwart HighFlow Product Suggesties en Nieuws 4
Hightower bitfenix kabels levertijd? HighFlow Product Suggesties en Nieuws 1
Ianovski Bitfenix ["Inspired by Nature"] Gamescom build Gallery & Build Logs 19
F BitFenix PWM fan extension 30 cm HighFlow Product Suggesties en Nieuws 4
U BitFenix Hydra Pro modden in 5.25inch lege optical drive casing Cases en Modding 2
Evanix Bitfenix Recon (white) Fancontroller HighFlow Product Reviews 0
Blokmeister LED mod op Bitfenix Shinobi XL white Cases en Modding 0
gerjanlubbers Bitfenix project silver. Gallery & Build Logs 1
R [VERKOCHT] BitFenix Merc Alpha Verkocht 2
D WC in een Bitfenix Prodigy Advies Waterkoeling Setup 28
Cygnitr0n Bitfenix Custom front panel HighFlow Product Suggesties en Nieuws 3
R Bitfenix Prodigy Windowed Side Panel White HighFlow Product Suggesties en Nieuws 2
Cygnitr0n Bitfenix Alchemy Multisleeved Cables HighFlow Product Suggesties en Nieuws 2
NAVYVIPER Bitfenix 4-Pin 12V Verlengkabel - 45 cm HighFlow Product Suggesties en Nieuws 6
M Watergekoelde Bitfenix Prodigy Gallery & Build Logs 21
l3p [IN-ACTIVE] Compleet BitFenix Alchemy Premium modding series pakket Verkocht 4
psyduck170 Bitfenix Recon White HighFlow Product Suggesties en Nieuws 2
tomasvanderpijl Bitfenix verleng kabels HighFlow Product Suggesties en Nieuws 5
Thierry BitFenix M-ITX Prodigy HighFlow Product Suggesties en Nieuws 29
Besje BitFenix Recon fan controller HighFlow Product Suggesties en Nieuws 15
psyduck170 BitFenix extension cables HighFlow Product Suggesties en Nieuws 8
7 BitFenix Alchemy LED Strips HighFlow Product Suggesties en Nieuws 17
M bitfenix shinobi XL HighFlow Product Suggesties en Nieuws 11
J Bitfenix Outlaw HighFlow Product Suggesties en Nieuws 8
A BitFenix Shinobi Window Case Review HighFlow Product Reviews 7
S Internal USB 3.0 Adapter bitfenix HighFlow Product Suggesties en Nieuws 19
P Bitfenix Alchemy Kabels HighFlow Product Suggesties en Nieuws 88
R BitFenix Survivor HighFlow Product Suggesties en Nieuws 36
Jason Singularity Computers Spectre 3.0 Zwart & Zilver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 Elite HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black & Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black/Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 2.0 Case, 10% korting aanbieding HighFlow Product Suggesties en Nieuws 0
Freddy Singularity Computers Spectre 2.0 case / behuizing HighFlow Product Suggesties en Nieuws 8
Besje Vraagjes over 140mm rad, Bitspower Spectre fans, en EK Supreme HF. Advies Waterkoeling Setup 3
dark viper zwolle Spectre Pro LED rood 120mm HighFlow Product Suggesties en Nieuws 2
B plaatsing radiator Eisbaer pro aurora Waterkoeling 4
Bl4ckj4ck666 eiskoffer pro HighFlow Computer Cooling Shop 3
