Am I buying the right stuff??
AciD_RaiN
Hi there. I am making my first custom water cooling setup and I need to know if I am buying the right size of fittings and tubing... Here is my cart:
PrimoChill Clip / Slangklem (1/2) kunststof UV Brite Green
Code: C-34-UVBG - SKU: C-34-UVBG
Direct leverbaar, ruim op voorraad.
Qty: x €1,25 = €7,50
Click here for more details
13MM (1/2 ID - 3/4 OD) Enzotech Schroeffitting - G1/4 Matt Black BCFS-ID1/2-OD3/4
Code: BCFS-ID1/2-OD3/4 - SKU: BCFS-ID1/2-OD3/4
Direct leverbaar, beperkt op voorraad.
Qty: x €7,98 = €47,88
Feser Tube UV - 1/2" ID - 3/4" OD - ACID GREEN
Code: TFC63
Qty: x €7,90 = €39,50
Revoltec Ultra Bright Cold UV Light - 10cm TWIN set
Code: RM094 - SKU: RM094
Qty: x €7,95 = €7,95
Nexus 120MM Real Silent 1000RPM
Code: 1599 - SKU: D12SL-12 BW
Direct leverbaar, voldoende op voorraad.
Qty: x €6,99 = €41,94
Phobya G-Changer 360 Ver. 1.2 Black
Code: 35223 - SKU: 35223
Qty: x €70,00 = €70,00
XSPC DDC 5.25 Dual Bay Reservoir One
Code: DDCBAYONE - SKU: DDCBAYONE
Qty: x €52,96 = €52,96
Koolance Pump PMP-450
Code: PMP-450 - SKU: PMP-450
Qty: x €79,94 = €79,94
10MM (3/8) T Slang verbinder Zwart
Code: 63112
Qty: x €1,99 = €1,99
XSPC RayStorm CPU WaterBlock Intel - XS-RAYS-INT
Code: XS-RAYS-INT - SKU: XS-RAYS-INT
Qty: x €59,99 = €59,99
Enzotech G1/4 Matt Black Rotary Angle 1/2 Fitting BRCPS-G1/4-12-90
Code: BRCPS-G1/4-12-90 - SKU: BRCPS-G1/4-12-90
Qty: x €9,95 = €9,95
Welcome to our forums :)
It's easier if you copy/paste a link of your saved cart, the list above is hard to read.
But here are some few points you might want to change:
Enzotech compression fittings, those are currently not enough in stock and unknown shipping date, so it's better you choose the Bitspower Matt Black or Feser Black compression fittings.
The pump doesn't match the reservoir, you have to take this pump:
Koolance Pump PMP-400
What if I use the pump outside of the reservoir?? I really like this pump :)
The PMP-400 is also one of the strongest pumps, so you really don't have to worry about the performance.
But of course you can also choose this reservoir:
XSPC Acrylic Dual 5.25 bay Reservoir for Laing D5/MCP655/PMP-450 D5BAYRES
Then you can keep the PMP-450 in your cart.
The Thermochill fittings are OK, but you might have to use some (teflon) tape to make the hose a bit thicker at the place, where the fitting compresses the hose, because Thermochill fittings might be a little too loose if the hose get soft.
