Alternate top for MCP35X Reservoir?
dintid
Hello all.
I hope I post this in the right forum as I find it difficult to navigate in here.
Anyway, I have the MCP35x Reservoir from Switech and use the top as inlet for my flow. I have a tube (actually a bitspower thing) running inside the reservoir, Down towards the bottom, and below the top Water level. I can not use this port as a fill port as a result.
I would like to have an extra hole in the top to use as fillport.
I have thouht about drilling a hole and make some threadding for a plug, but I Wold rather if I could use an existing top instead.
I have looked at a top from Alphacool
Alphacool Coolplex bottom piece PM3xG1/4 50mm (Code: A29696) (OD 50mm ID 40mm)
Anyone know the exact thread size of the Swiftech reservoir (I have written to Swiftech, but not heard back yet).
And also thread size of Alphacol?
Bijlagen
    39,3 KB · Weergaven: 1
You could use this fitting in te top of the reservior, it hase 3 openings you can use.
Bitspower G1/4" Silver Shining Q-Rotarary Adapter
Hello Thierry. Thank you for your idea.
It will not Work though, due to positive pressure from the reservoir, as the inlet is led Down below waterlevel by a Bitspower Aqua tube
Bitspower G1/4 Deluxe White Aqua-Pipe I BP-DWWP-C17
I've tried to depict here how it works.
The center top inlet goes into the inner tube which goes below waterlevel. So that one can't be used as fillport, unless I use pressurized Water, and I don't want that - can cause all sorts of problems.
I need a hole, like I showed to the left. I don't mind how the top looks or where the holes are located. Don't even have to have a center hole.
The two Photos shows how I have to bleed and fill it now, which is annoying.
Here you can see why it doesn't matter how the top of the Reservoir looks, as it is hidden behind the double LCD display. It is hot and Cold Water (can't see Cold Water on the image though)
Bijlagen
    57,5 KB · Weergaven: 0
J Joost - Joost Streefkerk - i5 Alternate ( moet hem nog winnen: zie dit forum ;) ) Introductie: Stel jezelf en jouw PC voor 11
T Problem with mounting HWLabs GTS420 into the top of Meshify 2 XL Handleidingen en Installatie Tips 3
O Protium D5 Pump Top Waterkoeling 3
S Veel lucht in D5 top Waterkoeling 2
D top ek supremacy mx HighFlow Computer Cooling Shop 17
T Ander top op Revo D5 Waterkoeling 2
Bas9466 D5 Alphacool met pom hf top HighFlow Product Suggesties en Nieuws 4
TinusB Fittingen D5 mod top Waterkoeling 2
Ahtlon NesteQ RubberScrew magnet gebruiken met EK d5 top SCQ Waterkoeling 2
Hightower clear top voor de ek mosfet max iv gene-z HighFlow Product Suggesties en Nieuws 4
JanPieter Bitspower D5 MOD TOP - Black "S" Model - BP-D5TOPPS-BK HighFlow Product Suggesties en Nieuws 2
DutchChilles Combinatie Bitspower top en EK Housing voor DDC pomp Handleidingen en Installatie Tips 5
A 420 rad in top corsair obsedian 750d Cases en Modding 5
S D5 pomp/ Bitspower top Waterkoeling 34
Zwelgje Bitspower VG-NGTX780TI Nickel Plated ICE Black Acrylic Top HighFlow Product Suggesties en Nieuws 1
XenoMorpH Welke EK res op de EK-DDC Dual TOP V.2?? Waterkoeling 3
XenoMorpH [VERKOCHT] asus 7970-dc2-top Verkocht 1
faljukin Alphacool HF D5 TOP -Plexi G1/4 HighFlow Product Suggesties en Nieuws 4
fatal_error.be Bitspower CPU Block Summit EF (Intel) Clear Acrylic Top HighFlow Product Suggesties en Nieuws 5
P EK-D5 X-TOP CSQ - White Acetal HighFlow Product Suggesties en Nieuws 1
canonchiel [VERKOCHT] Asus Gtx 680 DC2 top Verkocht 2
WiSK EK-RES X3 - Multiport TOP HighFlow Product Suggesties en Nieuws 7
Cygnitr0n [VERKOCHT] BitsPower D5 Top V2 Verkocht 1
F [IN-ACTIVE] Bitspower D5 / MCP655 Dual Mod Top/Extreme Verkocht 0
canonchiel Welke top fitting Waterkoeling 2
Sw333t Bitspower VG-NGTX680 ICE Black Acrylic Top HighFlow Product Suggesties en Nieuws 4
P EK-D5 Dual TOP G1/4 CSQ - Acetal HighFlow Product Suggesties en Nieuws 1
E [VERKOCHT] swifttech MCP-655 + EK D5 X-TOP Verkocht 3
canonchiel [VERKOCHT] D5 Met Bitspower Mod kit en top Verkocht 7
canonchiel [CLOSED] D5 met bitspower mod kid en top Gesloten 9
H Levertijd Bitspower Black Freezer VG-NGTX690 ICE Black Acrylic Top BP-WBVGNGTX690ACIB HighFlow Computer Cooling Shop 3
psyduck170 plaatsing bitspower dual pump top Overige Koeling 4
k.3nny [IN-ACTIVE][TEAB]MCP 3SERIES aftermark top! Gevonden 4
arwin74 [GEVONDEN] te leen gevraagd d5 top Gevonden 2
