Aftermarket cooling voor de HD6870(club3d)
Wally1987
spam-meistert
Ik ben opzoek naar een aftermarket cooler voor mijn HD6870, mijn enige probleem is dat ik niet zoveel ruimte heb om een willekeurige cooler te pakken.
Ik kan de max ruimte nemen van de stock cooler, ook echt niet meer!!
Naast de kaart heb ik ook nog maar 1CM de ruimte..
Specificaties
Om verwarring te voorkomen, ja ze staan te ruil aangeboden omdat ik die optie open hou.
Of ik kan ze ruilen of er gaan Aftermarket coolers op.
The mounting hole spacing is the same as with the 5800 and 4800 series cards: 53 * 53 MM
This means that coolers that are compatible with these cards may be compatible with 6800 series cards. Most VGA coolers ship with at least eight sinks for the memory, which is enough for the memory on the 6800 series cards. So memory cooling should not be a problem.
One thing is different on the 6800 series cards: it's the VRM placement
The VRM's are placed to the left. Instead of being near the back of the card, they are located between the bracket and the GPU. On the 6870 they are cooled by the plate. On the 6850 they are cooled by heatsinks. Either way, they will need cooling. Most VGA coolers ship with VRM sinks. Since the VRM sinks on the 6850 are small and the 6800 cards dont use a lot of power I think most of these bundled VRM sinks will perform just fine. I do think there are some VGA coolers that have no room for VRM sinks in that location
I don't know if all boards have this layout. There may be custom PCB's with a different layout.
Wrapping it up:
If you want an aftermarket cooler for your HD 6870/ 6850 you can use a cooler that is compatible with the 5800 or 4800 series cards. You will need to check if the cooler leaves room for VRM sinks on the left of the GPU. But check the PCB layout first.
List of compatible Coolers
Scythe Musashi ( unconfirmed )
Confirmed: Arctic Cooling Accellero Twin Turbo Pro
Confirmed: Gelid Icy Vision
Confirmed: Universal Blocks that fit on 5800 and 4800 series cards
Confirmed: Zalman VF-3000
Confirmed: Thermalright Shaman
Confirmed: Thermalright Spitfire
Confirmed: Thermalright TRAD^2 NOTE: ON A NON REFERENCE BOARD WITH VRM AT THE BACK )
Confirmed: Xigmatek Bifrost AKA Ultra U-12 Carbon X4
Confirmed: Scythe Mushashi
Confirmed: Arctic cooling Acellero Xtreme
Confirmed: Arctic cooling Acellero S1
I will update this list and add incompatible coolers ( due to VRM ) as well.
So which one do I get?
I dont know . Aftermarket GPU cooling beats standard colling hands down. It is not only cooler but also more quiet. The only little downside is that the VRM cooling could be a bit worse than with the stock cooler but with these cards I dont think that is a very big problem. 6870's and 6850's are great, power efficient cards.
Some suggestions:
Arctic cooling accellero s1: cheap, decent performance, you will need your own fan.
Arctic cooling twin turbo pro: decent price, very good performance. Comes with good, quiet fans.
Scythe Mushashi: decent price, good performance, very slim cooler.
Gelid Icy vision: decent price, good performance.
Do you have one of these babies with an aftermarket cooler?
Please post your temps, your overclock, which card you own and what the PCB layout is like. And please tell us how the installation went. ( did you have to mod the cooler, were there moments of desperation? did you hack off a capacitor just to make things fit? ). Dont forget to add yourself to the ATI Aftermarket cooling database.
I really want to see what clocks these cards can achieve with aftermarket cooling
Die is duidelijk volgend probleem is de ruimte..
De meeste coolers die daar tussen staan zijn dual/triple slot coolers, ik mag max anderhalve slot gebruiken omdat je ook met de mounting aan de achterkand zit..
En er zit maar 1 cm "MAX" ruimte tussen PSU en kaarten
dit word idd een beetje een moeilijke...
wat zijn jou doelen eigenlijk? (performance/stilte??)
en waarom wil je van die stock cooler af (heb ook een 6870 maar vind die stock cooler zo goed dat ik voorlopig er niks mee van plan bent)
Deze twee zijn nogal aan de warme kant als ik een game speel, ze worden rond de 70 graden dat vind ik nogal warm..
Ik heb er al een een fan bij gezet aan de zijkant maar dat veranderde de temps maar 1 graad minder:S
En ik hou zelf ook van stillere koeling, het liefst geen geluid;)
zo te zien heb je hetzelfde probleem als wat ik had in mijn lianli v354. Zit niets anders op als je kaarten verkopen en een 6990 ervoor halen :) Heb ik ook gedaan. Nog geen sconden spijt van gehad. 6990 is nog sneller ook ivm je lanes op 8x draaien nu volgens mij :D (was bij mij ook het geval).
70 graden load kunnen ze makkelijk hebben het zijn gpu's die zijn gemaakt om wat warmer te lopen (en vinden ze ook helemaal niet erg)
in mijn ogen dus nogsteeds nergens voor nodig
een stevig koelende 1,5 slots hmm das een moeilijke...
70 graden warm? En dat in Crossfire?
You gotta be shitting me, dat is nog koel man. Zou je echt helemaal nergens druk om maken.
Als ze nou 90 graden werden oké, maar 70, zelfs onder load.....
Denk dat ze met een andere aftermarket koeler onder load nieteens zoveel koeler zullen worden. GPU's zijn nu eenmaal warmer dan CPU's.
@Dopestuff: Ben er niet zo super in weg, maar vond 70graden. al veel klinken.
@X-Tripiot: Dat zie ik nog niet zo snel gebeuren;)
@Vissa: zoals bovenstaand berichtje naar dopestuff, ben er niet bekend mee maar vond het wel erg warm op zichzelf al!
PS.
Zou een cooler met de fins van voor tot achter de kaart, genoeg koeling hebben aan een fan vanaf voor de kaart?
Dacht er vanochtend aan dat 1 kaart alle ruimte er onder heeft..
Dus ook het idee dan om 1 kaart naar onderen te plaatsen dmv. een flexibele pci-e extender?
maar wat zij de down sides van die dingen?
Simpel gezegd de onderste kaart een slot of 2 naar beneden te brengen met een extender,
dan kan ik in feite een willekeurige aftermarket cooler pakken. Feit blijft ik heb een klein bordje:p
de downsides van die dingen is dat je daar geen ruimte voor heb. ivm die je kaart 2,5 cm breder maakt en je vertelde maar 1 cm ruimte heb tov je psu. ook zitten de andere slots van je mobo in de weg voor het monteren van de kaart. Of je haalt 2 of 3 extender en leg je 2de kaart buiten je kast :D
gewoon 2 swiftec mcw 80 blokken halen of 2 ek vga supreme en dan de koppelingen opzij monteren. Dan kun je wel de slangen kwijt. en gebruik je voor de ram etc de ramkits van Arctic Cooling VR001 - AMD 5XXX / 4XXX RAM Sink Set
Die komen behoorlijk overeen met de 6870 delen.
ideeen opdoen : http://hardforum.com/showthread.php?t=1523895
maar als hij flexibel is kan het toch onder het mobo geplaatst worden?
Het zou technisch gezien toch niet veel breder(dieper) als het moeder bord zijn toch?
Thankzz voor de link krijg er wel ideeën van idd.:p
onder het mobo.. dat moet je me dan toch wel even uit gaan leggen?? want jij heb een matx bord met 5 sloten en een 5 slots kast. dus waar wil je dan die kaart kwijt waar geen mobo zit?
alain-s MSI Aftermarket koeler HighFlow Product Suggesties en Nieuws 13
olympus aftermarket cooler voor een hd4870x2 Problemen & Oplossingen 2
C Threadripper 3990x cooling advise Advies Waterkoeling Setup 5
G Watercool VRM cooling DYI HighFlow Product Suggesties en Nieuws 5
C Info componenten custom liquid cooling set Advies Waterkoeling Setup 26
Willius Kingpin Extreme Cooling Dragon F1 HighFlow Product Suggesties en Nieuws 7
Source Ideeën voor externe cooling Cases en Modding 8
Freddy EK-Predator is setting a new standard for AIO liquid cooling! HighFlow Product Suggesties en Nieuws 6
A liquid cooling system Advies Waterkoeling Setup 1
I EKWB cooling configurator fc6870 Waterkoeling 18
X Grote of kleine fans voor cooling pad? Overige Koeling 4
M Feser One Cooling Fluid's (Vooral Oranje) Waterkoeling 0
D Arctic Cooling Accelero Twin Turbo 6990 HighFlow Product Suggesties en Nieuws 3
F Arctic cooling Twin Turbo II Handleidingen en Installatie Tips 1
T water cooling pc maken Advies Waterkoeling Setup 1
Freddy Bitspower X-Station Universal Cooling After Module - UV - BP-XSUCAM-UV HighFlow Product Suggesties en Nieuws 1
Draecko Arctic Cooling Accelero XTREME 7970 HighFlow Product Suggesties en Nieuws 10
M Cooling voor mijn XFX 4870x2 Overige Koeling 9
Singular1ty Innovation Cooling Diamond 24 HighFlow Product Suggesties en Nieuws 6
R Arctic Cooling Accelero Twin Turbo 6990 HighFlow Product Suggesties en Nieuws 2
M Feser One cooling fluid - UV Pink HighFlow Product Suggesties en Nieuws 2
F Plakkende thermaltape voor Arctic Cooling Accelero XTREME? Overige Koeling 15
T i7 920, 295GTX H2O (compleet systeem) cooling waarde? Gesloten 1
ShadowBumble Water cooling setup Project Aqua Advies Waterkoeling Setup 7
P water cooling set Advies Waterkoeling Setup 12
Alex EK H3O Advanced Liquid Cooling Kit HighFlow Product Suggesties en Nieuws 11
W VR passief cooling. Waterkoeling 2
Dustyrick [IN-ACTIVE] Arctic Cooling Accelero S1 Rev. 2 Gevonden 4
M5rvii [IN-ACTIVE] Extreem cooling : cpu isolatie , tubing voor tec Gevonden 1
Blackruby Beginners Guide To Water Cooling Handleidingen en Installatie Tips 9
