Vannos
upgrading.......
zal waarschijnlijk wel wat hulp moeten hebben bij deze bios. Tis allemaal heel anders dan het overclocken van een Q9450
heb hier al wat settings.
Genie BIOS
Exit Setup Shutdown-Mode 2
-O.C. Fail Retry Counter-Enabled
- O.C. Fail CMOS Reload-Disabled
- PPM Function-Disabled
- Turbo Mode Function-Disabled
- 1 core Max Turbo Ratio-26 X
- 2 core Max Turbo Ratio-25 X
- 3 core Max Turbo Ratio-25 X
- 4 core Max Turbo Ratio-25 X
-CPU Non-Turbo Clock Ratio-20 X
- QPI Control Settings-Enabled
- QPI Link Fast Mode-Enabled
- QPI Frequency-4.800g GT /s
- CPU Base Clock (BCLK)-133-150-170-190 Mhz enz enz
- Boot Up CPU Base Clock-AUTO
- PCIE Clock-100 Mhz
- DRAM Frequency-1333Mhz
- UnCore Frequency-2666Mhz
- CPU Spread Spectrum-Disabled
- PCIE Spread Spectrum-Disabled
CPU Feature
- Set VR Current Limit Max-Disabled
- Thermal Management Control-Disabled
- EIST Function-Disabled
- CxE Function-Disabled
- Execute Disable Bit-Disabled
- Virtualization Technology-Disabled
- TDC Enable-Disabled
- TDC Limit-0
- TDP Enable-Disabled
- TDP Limit-0
- Intel HT Technology-Enabled
- Active Processor Cores-All
Voltage Settings
- O.C. Shut Down Free-Enable O.C.S.D.F
- CPU VID Control-1.2100-12500 enz enz
- CPU VID Special Add Limit-Enabled
- CPU VID Special Add-Auto
- Vcore Droop Control-Enabled
- DRAM Bus Voltage-1.850v
- DRAM PWM Switch Frequency-Nominal Frequency
- DRAM PWM Phase Control-2 Phase Operation
- CPU VTT Special Add-AUTO
- CPU VTT Voltage-1.42v
- VTT PWM Switch Frequency-Nominal Frequency
- VTT PWM Phase Control-2 Phase Operation
- CPU PLL Voltage-1.80v
- IOH/ICH 1.1V Voltage-1.11v
- IOH Analog Voltage-1.20-125-enz enz
- ICH 1.5 Voltage-1.5v
- ICH 1.05V Voltage-1.05v
- DIMM 1/2 DQ/DQSTB Bus VREF--00.0%
- DIMM 3/4 DQ/DQSTB Bus VREF--00.0%
- DIMM 5/6 DQ/DQSTB Bus VREF--00.0%
- ADDR/CMD VREF Control-Disabled
- DIMM 1/2 ADDR/CMD Bus VREF-110
- DIMM 3/4 ADDR/CMD Bus VREF-110
- DIMM 5/6 ADDR/CMD Bus VREF-110
- CPU QPI Drive Strength-Normal
- IOH QPI Drive Strength-Normal
DRAM Timing:
- Memory Control Setting-AUTO
- Memory LowGap-1536M
- DRAM Command Rate-1N
- CAS Latency Time (tCL)-6
- RAS# to CAS# Delay (tRCD)-6
- RAS# Precharge (tRP)-7
- Precharge Delay (tRAS)-22
- REF to ACT Delay (tRFC)-72
- Write to PRE Delay (tWR)-AUTO
- Rank Write to Read (tWTR)-AUTO
- ACT to ACT Delay (tRRD)-AUTO
- Row Cycle Time (tRC)-AUTO
- Read CAS# Precharge (tRTP)-AUTO
- Four ACT WIN Time (tFAW)-AUTO
als er nog wat beter kan hoor ik het graag.
Kga nu kijken hoe ver de cpu wil
Genie BIOS
CPU Feature
- TDC Limit-0
- TDP Limit-0
Voltage Settings
DRAM Timing:
