900D uitbreiding, verbeter punten.
Zippel202
beste Forumleden!
Ik heb nu dit in mijn pc kast:
Windows 8.1 x64 ( When 10 comes out, i updated to Windows 10!)
Case: Corsair Obsidian 900D
Supply: Corsair 1200i
CPU: FX9590 @ 5.0 GHz CPU Block: EK-Supremacy EVO BLUE Edition
GPU 1: Sapphire R9 290X
GPU 1 Block: EK-FC R9-290X - Acetal
GPU 2: Sapphire R9 290X
GPU 2 Block: EK-FC R9-290X - Acetal
Pump 2x: EK-DCP 4.0 PWM X-RES
Rad 2x: EK-CoolStream PE 480 Radiator
Motherboard: Asus Crosshair V formula Z
Ram: Corsair Dominator platinum 32 GB (4x8gb) 1600MHz
Samsung 840 Pro SSD 128 GB + 2000 GB + 3000GB Hardeschijf ( HDD )
Triple Screen: Benq xl2411z 144Hz
Maar ik zou graag wat verbetering en uitbreiding willen gaan doen, Zoals: de reservoirs ophangen. betere fans.een aftap punt maken en van blauwe kleur naar rode kleur willen gaan als vloeistof en fans:)
Iemand beteren iedeen of afwerk punten?
Laat het weten!
Gr:eusa_drool:
Hier de foto,s :
[img=http://www47.zippyshare.com/thumb/MBdzu0bk/file.html][/img]
[img=http://www47.zippyshare.com/thumb/w98l0mmu/file.html][/img]
[img=http://www47.zippyshare.com/thumb/eMLI08dP/file.html][/img]
[img=http://www47.zippyshare.com/thumb/4FtXVxax/file.html][/img]
[img=http://www47.zippyshare.com/thumb/TqjKGtbS/file.html][/img]
[img=http://www47.zippyshare.com/thumb/FeCqMrbH/file.html][/img]
[img=http://www47.zippyshare.com/thumb/dQZ5rmuq/file.html][/img]
[img=http://www47.zippyshare.com/thumb/Yb7b7iTp/file.html][/img]
[img=http://www47.zippyshare.com/thumb/q6lfjikw/file.html][/img]
[img=http://www47.zippyshare.com/thumb/KallCU4v/file.html][/img]
[img=http://www47.zippyshare.com/thumb/FbNbPwfu/file.html][/img]
[img=http://www47.zippyshare.com/thumb/jiqghoIy/file.html][/img]
[img=http://www47.zippyshare.com/thumb/5gVAsAmf/file.html][/img]
[img=http://www47.zippyshare.com/thumb/h0UaHbLI/file.html][/img]
[img=http://www47.zippyshare.com/thumb/UxMvFT4N/file.html][/img]
[img=http://www47.zippyshare.com/thumb/rlF2nMvW/file.html][/img]
[img=http://www4.zippyshare.com/thumb/ER4xBzHd/file.html][/img]
[img=http://www4.zippyshare.com/thumb/m1r0eXdk/file.html][/img]
[img=http://www4.zippyshare.com/thumb/H8GWQnJW/file.html][/img]
[img=http://www4.zippyshare.com/thumb/aLjtAwF0/file.html][/img]
Bijlagen
    58 KB · Weergaven: 2
    55,9 KB · Weergaven: 2
    89,8 KB · Weergaven: 5
    55,3 KB · Weergaven: 2
    59,9 KB · Weergaven: 2
    49,7 KB · Weergaven: 2
    48,4 KB · Weergaven: 2
    73,1 KB · Weergaven: 3
    69,6 KB · Weergaven: 3
    47,8 KB · Weergaven: 2
Zippel202 Wouter 900D Uitbreiding
beste Forumleden!
Laat het weten!
:080:
Gr
dus als ik voor een reservoir zou moeten kiezen voor in de 900D kast met bijhorende klemmen om hem te monteren, welke zou u dan aanbevelen? en welke fans van 120mm van PWM? en welke fittingen zijn dat... kunt u een winkel wagen aanmaken voor me welke ik dan zou moeten hebben? :) dan weet ik hoeveel het is en dat ik ook echt de goede onderdelen heb :)...
En ik heb totaal 12 dezelfde vans nodig met pwm:) en de onderdelen voor een aftap punt:)
Alvast bedankt!
Ik zou eerst de psu kabels vervangen door de rode of zwarte sleeved kabels van Corsair, de res/pomp zou ik aan de hdd cage en aan de moedrbord tray vast schroeven, dit zorgt al voor een meer clean look, de slangen strakker leggen met behulp van bochten en extensions. Ik dacht bij de EK res/pump dat je de res kon vervangen door een hoger model.Als je fans besteld, bestel dan bij een merk en type, zelfs de 140mm fan achter en de fans voor in het front, dit oogt ook weer mooier. ik weet niet waarom de onderste fans in pull staan, voor het minste stof in de kast moet je meer lucht binnen blazen als uit, positieve lucht druk.Heb je nog een cathode lamp, vervang deze door een led strip, dit geeft weer een mooiere belichting, bv rode leds achter het mobo of aan de zijkanten van de kast, of onderin de kast, zodat deze een mooie gloed over het bureau geeft.
Fans zou ik voor de Corsairs gaan die je nu hebt, gewoon de rode ringen gebruiken, slang zou ik voor de primochill advance lrt dit in 10/16mm of 13/19, dit als clear slang of kleur, de dezelfde maat van slang gebruiken als de fittings die je nu hebt gaat ook, de leds kan je ook vinden bij highflow onder verlichting, De aparte acryl reservoir buis vind je ook bij highflow, niemand kan een winkelwagen maken voor iemands anders, daar smaken verschillen, welk budget, welke kwaliteit. Gewoon eens een avondje niet gamen, maar eens de highflow shop afstruinen naar materiaal, dit is de enige mogelijkheid, ieder heeft een ander gedacht. Je kan ook eens 900D water cooled ingeven bij google, bij de video's en foto's vind men veel ideeën.
S BIG RED 900D Steves1990 Gallery & Build Logs 38
Bjorn@demichiel.nl 900D First WC Build Gallery & Build Logs 233
M First loop - Corsair 900D - orange - Unnamed :O Gallery & Build Logs 36
B Waterkoeling i7 3770k 7970top dcu2 corsair 900D ongeveer 500 euro Advies Waterkoeling Setup 40
L 900D Quad Crossfire Build Advies Waterkoeling Setup 10
W 800D/900D met i5 2500k en R 290 Crossfire Advies Waterkoeling Setup 6
C LiquidRZR rebuild 900D Gallery & Build Logs 34
cederieck Obsidian 900D Gallery & Build Logs 25
B corsair 900d fabricage fout of express zo gedaan? Cases en Modding 4
B 900D *nameless* Gallery & Build Logs 78
S Corsair Obsidian 900D (Watergekoeld) Gallery & Build Logs 10
J Corsair 900D Advies Waterkoeling Setup 6
Cruise 900D - Titan waterkoeling build Advies Waterkoeling Setup 13
ChillPascal Corsair 900D HighFlow Product Suggesties en Nieuws 35
XenoMorpH Zoek functie uitbreiding HighFlow Webshop 2
U Hulp uitbreiding watercoolingsetup Advies Waterkoeling Setup 2
O Asus Hero VI, 4770K, H220 en Sapphire R9 290 CrossfireX - benodigdheden uitbreiding Advies Waterkoeling Setup 5
D Uitbreiding Waterkoeling Advies Waterkoeling Setup 7
D Is mijn radiator voldoende bij uitbreiding? Waterkoeling 6
R Advies uitbreiding Waterkoeling gevraagd. Waterkoeling 4
Colossus Uitbreiding Xigmatek Serie HighFlow Product Suggesties en Nieuws 2
aadje93 aadje z'n waterkoelingkje (uitbreiding) Gallery & Build Logs 6
Q [GPU+RAM WC] Uitbreiding Loop Waterkoeling 7
N Uitbreiding loop, genoeg koelvermogen? Advies Waterkoeling Setup 7
